i got a question when asking for the brake parts at autozone they had 2 different kinds of brake calipers ones with jd6 brakes or jd7 whats the difference is it bigger brake setup? i looked online at there website and it says for the pads you can either get pads for ones with 11 5/32 rear drums or 13'' rear drums asked 84 c20 which should i get?
would the calipers be smaller for the half ton? versus 3/4 i'd like to get the biggest ones they have that will bolt up to this combo they couldn't tell me what the difference in the 2 calipers i'm thinking the jd6 and jd7 brakes would either mean it has bigger caliper/drums or smaller?
Are you sure they have the same brakes? They have 2 different types of brake options and each one has a different # caliper which makes me think they had a bigger set of caliper option from factory also there's a price difference of like $13 between the 2
the dana 44 and the corp. 10 bolt had different part numbers. Here is the proof it works:
Thanks for the info I wanted to see if there was a larger front caliper option from factory so it doesn't matter if I get the cheaper calipers or the more expensive ones? They couldn't tell me what the difference was between the 2 other then they had a price difference of like $15 also how many piston are these calipers?
