truck starts without key - Ford Truck Enthusiasts Forums
Old 03-21-2011, 11:47 AM
ItsAFord55's Avatar
ItsAFord55 ItsAFord55 is offline
ItsAFord55 is starting off with a positive reputation.
my truck starts without the keys in it. is it hard to change the ingition switch?
Old 03-21-2011, 11:55 AM
Nealcrenshaw's Avatar
Nealcrenshaw Nealcrenshaw is offline
Nealcrenshaw is starting off with a positive reputation.
I would love that!!! Just dont tell no one you dont trust.
But sounds like the lock cylinder is no good,the ignition switch is fine by you being able to start it minus the key.
Old 03-21-2011, 12:01 PM
loseboltssinkships loseboltssinkships is offline
loseboltssinkships is starting off with a positive reputation.
Ya it was fun for awhile till I was muddin and my friends would joy ride my truck while I was dirtbiking
Old 03-21-2011, 12:31 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
What is your address ???
Old 03-21-2011, 01:14 PM
92 Black Nite's Avatar
92 Black Nite 92 Black Nite is offline
92 Black Nite is starting off with a positive reputation.
Quote:
lew52, They were my thoughts too!!!!!!!!!!!!!!!!!
But really it is not that hard, best bet is to get a manual. And you live on what street now?????????????????
I would lock your doors till you fix it.
Old 03-21-2011, 01:26 PM
streetlude95's Avatar
streetlude95 streetlude95 is offline
streetlude95 is starting off with a positive reputation.
mine is the same way, but after a while the ignition screwed up so i had to put in a push button in. so now only i can start my truck lol
Old 03-21-2011, 02:04 PM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Quote:
Turn the ignition cylinder to the "ON" position. There is a small pin that retains the cylinder in the column which will need to be pushed in (a pick or ballpoint pen does the trick). While pushing in the pin, pull the cylinder out of the column. To install the new cylinder, just slide it into place.
-Rod
Old 03-22-2011, 11:14 PM
JIMROY JIMROY is offline
JIMROY is starting off with a positive reputation.
I believe its Mitchells manual that shows the best description on how to change the lock cylinder. The lock cylinder moves a rod that is connected to your ignition switch which is located on the top of the steering column below the dash board, two nuts to take off and replace the switch. you have to insert the rod into the groove in bottom of switch and into a hole in the switch. Plug the plug back into switch, check timing to make sure the lock cylinder will turn the vechicle on and off. then, tighten the nuts. all done. Just did mine yesterday. For some reason my heater fan stays on when i shut off the ignition,as do the turn signals and backup lites if in reverse.( manual tranmission). Gotta make sure i shut everything down or i come out and have a dead battery.
Old 03-23-2011, 10:28 AM
Xclimation's Avatar
Xclimation Xclimation is offline
Xclimation is starting off with a positive reputation.
What White Max said. Its a known problem with these trucks. Mine did this for a couple of years. I finally plopped down the $16.00USD to buy a new cylinder. It literally is a 5 - 10 minute job. There is a hole underneath the ignition key cylinder. just put a skinny object (I used a torx screw driver) in the hole, turn the key while pulling out on the ignition key assembly. It might take a little doing, but ideally it pulls right out when you get a feel for it.
I highly recommend fixing it. The couple of times I let others borrow my truck; they accidentally left the ignition in the "ACC" position which caused the battery to drain.
The cons of this is you will have a separate ignition key from your door key. I thought it would be a major inconvenience, but it actually has some advantages. You can have them "keyed" to be the same but it costs money.
From a safety standpoint, there have been some accidents caused by this problem. Not too long ago a 5 year kid started his grandmother's truck and drove it into a swimming pool!
Old 03-24-2011, 04:24 AM
I actually liked mine not needing a key. I was a FireFighter for 27 years. In the middle of the nite when my pager went off , I didn't have to look for keys. Just jump into my clothes , fire the old girl off and haul *** to the station. I had a 76 Nova that was the same way , it was mighty handy.
Key Fob for Remote Start and no push button start jdunk54nl 2017 Super Duty 10 02-01-2017 10:15 PM
1992 Bronco Ignition Shanghai 1978 - 1996 Big Bronco 1 12-23-2015 02:39 AM
94 Ranger, 5-spd won't start with a key Liza Phillips Gay Ranger & B-Series 4 03-07-2015 07:44 PM
Copying Keys, Embedded Chip. Orpackrat 1997 - 2003 F150 2 09-14-2010 10:54 PM
replacement keys stecz Excursion - King of SUVs 3 07-24-2003 06:24 PM
Tags
1986, 2000, 94, f150, f250, f350, ford, ignition, key, keys, screwdriver, start, starts, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
