Part numbers for body side mouldings '95 crew XLT?
Old 03-23-2011, 09:33 PM
VIPERK30's Avatar
VIPERK30
VIPERK30 is offline
Anyone have access to the Ford part numbers for the body side mouldings (trim). The truck is a '95 crew cab dually XLT. I need the pieces on the dually flares. Any help would be appreciated.
Old 03-23-2011, 10:16 PM
goodB0Y's Avatar
goodB0Y
goodB0Y is offline
I dont have any part numbers...but I did once price moulding from ford...it was crazy expensive, and came in a kit. You could phone your local dealer and see what they have.
Or you could try your local auto body supplier... they should have a book and or a sample board you can look at with dozens of different mouldings... my guess is that you could find the exact or very similar moulding. They might even have a big roll of it and sell it by the foot!
hope that helps
Old 03-24-2011, 05:26 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I saw it in the NPD or LMC catalog.
Old 03-24-2011, 05:47 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
There are no factory body side mouldings on the flares. Are you referring to wheel opening mouldings? If so, DRW's did not come with wheel opening mouldings. Only available w/SRW.
1987/98 F350 Crew Cab body side-lower mouldings, black w/bright insert: Front fender, front door, rear door, cab corner, front of bed, rear of bed.
Nastynick
03-13-2016 10:19 AM
genscripter
04-20-2013 11:52 AM
96 Bronco XLT
1978 - 1996 Big Bronco
07-17-2012 09:31 AM
jim48
6.7L Power Stroke Diesel
18
05-09-2011 08:35 AM
CountryBumkin
04-25-2011 06:48 AM
Quick Reply: Part numbers for body side mouldings '95 crew XLT?
