Still have road walk after Redhead install
Old 03-21-2011, 09:34 AM
riverrat41's Avatar
riverrat41
riverrat41 is offline
The symptoms I had before the Redhead install was slack in the box so that made the truck wander/road hunt at speeds over 60mph.Here is what has been changed and checked.All front steering components have been checked and are good(tie rods,ect)New Redhead installed,front end alignment done,new ball joints,Powerslot rotors,dropdown and sway bar bushings-1-2 years ago.
I am still getting the road hunt over 60mph.No slop in steering now,it is tight.I am looking for suggestions on what I should look for next??Could wore out front spring bushings cause this?I have new 265x75x16 Hankook Dynapro MT tires.
http://www.hankooktireusa.com/Produc...um=4&FnCode=04
Symptoms:Road hunt and ''the clunk'' turning left or right at slow speed.
Thanks Folks!
Old 03-21-2011, 09:49 AM
milleroutdoors's Avatar
milleroutdoors
milleroutdoors is offline
Yes spring bushings can cause this. I have to replace another bushing in in my POS revtech springs for this same issue.
Old 03-21-2011, 09:56 AM
riverrat41's Avatar
riverrat41
I was afraid of that,I may have to call in re-inforcments for this one.Looks and have heard it is a PITA
Old 03-21-2011, 11:10 AM
Night Crawler's Avatar
Night Crawler
Night Crawler is offline
what about track bar?
Old 03-21-2011, 11:21 AM
riverrat41's Avatar
riverrat41
I think you are right on my left and right pop.It is time to tighten and loctite the track bar camber nut on my leveling kit.Thanks
I will admit I am not the best front end man around by no means so I took it to a guy I went to HS with that is in that business.He checked it out and found nothing loose/worn and then he lined it up.Sooooo,I do not know what else to do.
The spring bushing do need changing(260k and i get down in some rough river bottoms) and I will get that done tomorrow.
I am just looking for ya'lls help.
Old 03-21-2011, 02:04 PM
remhaust's Avatar
remhaust
remhaust is offline
Mine does the same thing, thats one of the 2 things I hate about my truck.But mine does it all the time at any speeds, with stock tires. I have a friend of a friend that heard to change the tires,but he put had stock size but not stock brand. So he changed them to OEM tires and was instanly fixt. I havent done anything with mine yet.
Old 03-21-2011, 02:28 PM
Muktown's Avatar
Muktown
Muktown is offline
I chased road walk the entire time I had my obs. New everything in the front. It was scary towing with it. Turned out to be the tires
Old 03-21-2011, 03:21 PM
riverrat41's Avatar
riverrat41
I'm with ya'll.It very well could be the tires.If you look at the tread directions with them being one way and then the other I am wonderring if that ain't my problem?
Old 03-21-2011, 03:36 PM
Brother Les's Avatar
Brother Les
Brother Les is offline
Had a walk to the left years ago, rotated the tires and it was straight as a string. Easy check before you try anything else.
Old 03-21-2011, 04:03 PM
big poppa's Avatar
big poppa
big poppa is offline
Interesting note with the tires because some tires got an arrow showing the recommended rotation of that specific tire on the rim. Good luck Barry, hope its a easy one for yaa..
Old 03-21-2011, 04:16 PM
muddman77's Avatar
muddman77
muddman77 is offline
I'm in the same boat. New moog ball joints and tie rods, new red head box, new bilsteins. I talked to an old guy at an alignment shop and he told me the torque was to high on my ball joint, and that ford had a TSB on it, making trucks have bad memory steer. I'm gonna re-torque mine and if that dont fix it may be lookn at new tires. I'm run'n 305' MasterCraft which are D's, on a ten inch rim, may go back to stock, Or trade it off....dont know
Old 03-21-2011, 07:17 PM
F350-6's Avatar
F350-6
F350-6 is offline
If it's tires, that should be easy to figure out. If all goes as planned, I'll have 4 BFG AT 285's on mounted on wheels I can let you borrow for a few weeks to help diagnose this.
Old 03-21-2011, 07:48 PM
riverrat41's Avatar
riverrat41
Thanks Pops,it is about to drive me crazy.
I rotated them and that did not help.I would'nt think it was the nitrogen I have in them???
We may have to swap,if changing the leaf spring bushings does'nt help I do not know what else to do.
Old 03-21-2011, 08:24 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
I was all for the tires being the culprit, but ya tried that. Can your front end friend dial in a little more positive caster? That will take the twitch out of steering.
Old 03-21-2011, 08:56 PM
riverrat41's Avatar
riverrat41
We will see what the new bushings do but I am in suspect of the tires as well.We can swap tires with Chris this weekend.
Quick Reply: Still have road walk after Redhead install
