Factory -vs.- Aftermarket wheel weight ratings
Old 03-21-2011, 09:28 AM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
Just curious what the weight capacity rating is for our factory aluminum rims if anybody knows.
I am considering aftermarket wheels and since I tow heavy with the family inside I want to know this stuff.
I am kind of partial to the MT Classics. They look as close to factor as possible with just a touch of aftermarket to make them look nice.
Also I was considering a tad larger than stock 16". Would they be rated higher.
Does anybody know what MT rates their rims at too?
Old 03-21-2011, 09:37 AM
Neal 97 250
OK so I found that the Classics I mentioned are rated at 3100 lbs. But still curious what the factory ones are rated at and what other wheel options I should consider using based on wheel capacities.
Old 03-21-2011, 09:50 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
Ultra 164's are pretty close to stock appearance.
Old 03-21-2011, 11:39 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
The Alcoa Classic 8 is rated at 3700 lbs or so at 110 PSI. Mine are about 12 years old and have a l think a 3300 lb or so rating. THe MT wheels are made by Alcoa. Or used to be anyway.
Old 03-21-2011, 06:32 PM
kellens's Avatar
kellens
kellens is offline
You may want to check out centerlinewheels.com. The wilderness series "scout" and "bullet" are very nice wheels similar to stock looks but with 10 holes instead of 8. They have a lot of sizes but all of them supposedly have the same 3200lb weight rating. All centerline wheels are forged and made in the USA! If you check they're overstock specials, I think you'll find they are some of the most affordable forged aluminum wheels you can find. If and when I ever upgrade wheels I will definitely be going with the 18x9 centerline scouts.
Old 03-23-2011, 11:57 AM
Neal 97 250
Still haven't figured it out yet. Does anybody know what our factory rims are rated at?
Owenage
2017+ Super Duty
07-18-2017 08:08 AM
tim665214
6.7L Power Stroke Diesel
01-15-2017 09:25 PM
Mudman
1999 to 2016 Super Duty
07-05-2016 11:51 AM
traildogg
20
10-14-2010 06:09 PM
Blubeast01
13
02-07-2005 10:53 PM
Quick Reply: Factory -vs.- Aftermarket wheel weight ratings
