What are you running and hows the mileage - Ford Truck Enthusiasts Forums
Old 03-21-2011, 01:53 AM
bigred.102 bigred.102 is offline
bigred.102 is starting off with a positive reputation.
I am curious to hear what others are getting for mileage out of these nice old trucks. What gear ratios engine mods that may or may not help. Just wondering what every one is running
I will start
Recent 300 mile trip averaged 13.2 mpg at 65mph in town its more in the line of gpf
1974 f250 highboy 6500lbs empty
390 ci
2 speed electric cooling fan
Holley dubble pumper spread bore with adapter to stock manifold off 352
about 11 to 1 compression ratio high lift/overlap cam timing at 6* advanced (still knocks sometimes)
hooker competition headers 2.5 inch exost with thrush glasspacks true dual (5 feet of pipe on each side plus 27 inch glasspack)
4.10 gears 33x12.5 tiers and np435 trany
the truck always runs at 210* summer winter
lets hear what you all have and are getting
Old 03-21-2011, 10:30 AM
fair67driver fair67driver is offline
fair67driver is starting off with a positive reputation.
79 SC 250, 4x4 351m, 3.54 gears, bone stock with 235-85-16s--i get fuel yardage......between 10 and 11 depending if I am pulling my mower and little trailer. Ac only has a small effect on mine.
Old 03-21-2011, 10:36 AM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
this comes up every once in awhile. its actually pretty laughable. the best mod to make is to get a metro, or rabbit, or something along those lines, and save the truck for fun.
Old 03-21-2011, 11:26 AM
Canty Canty is offline
Canty is starting off with a positive reputation.
+1^ I have an Omni for that...but it is turbo charged so if I keep my foot in it I can get terrible gas mileage for that too.
I am running a 73, 360 stock, Autolite 2100 carb, auto, no A/C, stock gears in back (3.54 I think, tho I am not sure at all) and I get around 10mpg.
Old 03-21-2011, 12:50 PM
The truck doesn’t get used every day just for work and play, or when nothing else runs as it is so reliable. “Work hard play Harder!”
The get around car Saab 900 turbo if I’m nice it gets pretty good mileage however if I drive it hard it can get just as bad as the truck maybe worse. and a kz900 ltd for the summer
Old 03-21-2011, 02:02 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
76 F250 4x4, 315/75/16 tires, 4.10 gears np435/205, 445ci FE (look at my garage for details) I get about 9-11 mpg. Most of that hwy. Thats really babying it around. Put my foot in and I need the tanker to follow me around. Seriously I used $20 of gas in one trip across town hotrodding around. Must have only went 8 miles or so. Thats like 1.5mpg! haha
Old 03-21-2011, 03:27 PM
704 dentside man 704 dentside man is offline
704 dentside man is gaining momentum as a positive member of FTE.
I have 8 rigs that range from 33's-42's, with 3.55's-5.13's. Power is provided by mildly built 400's on up to a 521. All of them are backed by a C6. And when driving reasonably, none of my rigs get worse than 4mpg's...and go all the way up to 12mpg's.
Old 03-21-2011, 07:17 PM
SHO rescue 79 SHO rescue 79 is offline
SHO rescue 79 is starting off with a positive reputation.
79 f150 HD? 351m c6 2wd reg cab. Bad exhaust valve. I get 9.6 mpg mixed driving.
Old 03-22-2011, 12:06 AM
MikePacey's Avatar
MikePacey MikePacey is offline
MikePacey is starting off with a positive reputation.
My old 79 150 with a 302 AOD dana 60 rear never checked the rear gear but I do know it was super low probably 3:08 or 3:50. Best I got with it was 18 mpgs with lots of tuning and weight savings. Sold it to my bud and his dad and him have dropped the belt drivin fan for electric and a couple other things and net 20.
My current rig is a 75 f100 302 3 on the tree 9 inch rear. No idea on gear but I'm getting around 16.5. If you really put the time and effort in to tuning it correctly they don't do to bad.
Old 03-22-2011, 12:57 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Specs of my rig in my signature.... 3.54 rear gears and as aerodynamic as a sheet of drywall. Mileage? I like to say "Some"!
Seriously, 13 mpg is the absolute best I have ever pulled by really babying the throttle and hypermiling.... normally around 10 mpg but I really don't mind since it is a toy.... My DD gets 23 mpg highway, the 65 and 68 about 22 each, the S'Crew can get 18, and the 71 around 20.
Old 03-22-2011, 01:05 AM
This is great I love hearing about your trucks keep it coming
Old 03-22-2011, 12:08 PM
johnson2007's Avatar
johnson2007 johnson2007 is offline
johnson2007 is starting off with a positive reputation.
MY 79 F-150 with a hopped up 400, C6, 31" tires and 3.50 gears gets about 8mpg mixed driving and the best was 12.5 all highway doin about 65mph. I get about 5mpg in the winter in town...
Old 03-22-2011, 01:14 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
the '75 highboy gets 8mpg (my fun truck)
the '83 diesel Ranger gets 35mpg (my daily driver)
Old 03-22-2011, 09:58 PM
justforkicks's Avatar
justforkicks justforkicks is offline
justforkicks is gaining momentum as a positive member of FTE.
i got a 77 f150 4x4 (in the sig) 4spd with 33"s and true duals. no engine mods done to it. all town miles on it since i've had it. i probably get around 8-10 with it. was getting about 6 when i had the 36"s on it.
for the dd though i had a 91 Ranger STX 2.9l v6 5spd 4x4 with 29"s on it. got 19 at the best. last trip i took before it died i got 17 with it. got a 96 Ranger XLT now and i have yet to check the mileage (let alone drive it around enough to burn gas). it's a 2.3l I4 with a 5spd. short bed, standard cab, and 2wd.
Old 03-23-2011, 12:02 AM
NBC-Steve's Avatar
NBC-Steve NBC-Steve is offline
NBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to behold
I have a 79 F350 4X4 with a 400 4BBL edelbrock manifold and carb and I get around 10MPG if I keep my foot off the pedal.
My truck is not my daily driver, just my mistress.
Glasspack rumble question? Mitch1129 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 03-14-2015 06:36 PM
adding glasspacks question 5.8l choate 1987 - 1996 F150 & Larger F-Series Trucks 7 06-19-2014 01:48 PM
Glasspack BAD351W Exhaust Systems 26 03-30-2009 11:05 PM
thrush glasspacks anygood? maddmudder13 Exhaust Systems 10 07-30-2006 01:11 PM
3 inch exhaust luger 1978 - 1996 Big Bronco 8 09-09-2005 05:13 PM
Tags
410, 429, 65, 69, 75, c6, conversion, diesel, f100, f250, floor, ford, gears, mpg, runnig, tree, worse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
