Engine oil capcity for 5.4L triton
Old 03-20-2011, 11:15 PM
74broncosport's Avatar
74broncosport
74broncosport is offline
Alright here it is as info:
opened the drain plug and backed off the filter. Waited a good bit on a warm engine for the oil to drain.
Dipstick: hole on either side of the grid.
replaced the filter, capped everything, put in jug: (bulk) 5.3 quarts of synthetic Castrol 5W-20.....then 1 quart of same and pulled the dipstick (6.3 at this point): ----- oil-level mark was at top of grid...
Then, ran engine for ~10 minutes to fill the filter and let settle....reread and dipstick shows at bottom of grid (add 1 quart).
so, added 1 quart.....(7.3 at his point.)
Now the dipstick reads exactly between the top of the grid and the top hole.
over-fill.....crap.......7 quarts seems to be the perfect amount.
(have leveling lift on front)
Paul
Old 03-21-2011, 12:22 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Yes 7 quarts is the right amount in the 5.4.
Old 03-21-2011, 06:04 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
Just like it says in the owner's manual.
Old 03-29-2011, 01:52 AM
redrush40's Avatar
redrush40
redrush40 is offline
I have been putting in a total of 7.5 quarts of Mobile 1.
That is probably because I put about 1/2 quart in the oil filter to pre-lube it up.
Does anyone else do that trick? If I don't do it, I usually get a hard-start and it takes a bit for oil pressure to level off.
Tony.
Old 03-29-2011, 06:12 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
I put the first 1/2 quart of oil in the filter too, but never exceed 7 quarts.
Old 04-02-2011, 01:55 PM
Steve_Uzi's Avatar
Steve_Uzi
Steve_Uzi is offline
So True.... but I believe older 5.4 2v's used only 6 quarts of oil.. I know it doesn't apply to owners of the 3v 5.4. But I had a Stealership only put in 6 quarts - Well because they are stupid ...
Thankfully 1 quart low isn't going to KILL the engine and I found it the next day as I always check the Quality of work peformed by Stealership
So the service manager drove to my house and put the quart in as well as he gave me a $50 off coupon on next service
Old 02-20-2014, 09:23 PM
Sal1707's Avatar
Sal1707
Sal1707 is offline
what oil do most of yall use dino or synthetic?
Old 02-22-2014, 09:45 PM
papasmurf40's Avatar
papasmurf40
papasmurf40 is offline
Motorcraft 5w20 semi synthetic from Wally World(Walmart) is what I personally use but, I think any good quality brand name oil with specs the same as called for in the owners manual will work fine. Do use Motorcraft oil filters as they seem to be better than other filters.
I have to go to the US of A to get my oil as Ford doesn't sell Motorcraft oil other than at stealerships in Canada.
tim665214
6.7L Power Stroke Diesel
10-28-2016 01:46 PM
mslopnick
15
09-30-2016 04:44 PM
Tawn
6.2L V8
17
07-06-2016 05:47 PM
JustinRo2014F250
15
04-02-2014 08:47 PM
HDMustF250
01-21-2004 12:43 PM
Quick Reply: Engine oil capcity for 5.4L triton
