Engine oil capcity for 5.4L triton - Ford Truck Enthusiasts Forums
Old 03-20-2011, 11:15 PM
74broncosport's Avatar
74broncosport 74broncosport is offline
74broncosport is starting off with a positive reputation.
Alright here it is as info:
opened the drain plug and backed off the filter. Waited a good bit on a warm engine for the oil to drain.
Dipstick: hole on either side of the grid.
replaced the filter, capped everything, put in jug: (bulk) 5.3 quarts of synthetic Castrol 5W-20.....then 1 quart of same and pulled the dipstick (6.3 at this point): ----- oil-level mark was at top of grid...
Then, ran engine for ~10 minutes to fill the filter and let settle....reread and dipstick shows at bottom of grid (add 1 quart).
so, added 1 quart.....(7.3 at his point.)
Now the dipstick reads exactly between the top of the grid and the top hole.
over-fill.....crap.......7 quarts seems to be the perfect amount.
(have leveling lift on front)
Paul
Old 03-21-2011, 12:22 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Yes 7 quarts is the right amount in the 5.4.
Old 03-21-2011, 06:04 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
Just like it says in the owner's manual.
Old 03-29-2011, 01:52 AM
redrush40 redrush40 is offline
redrush40 is starting off with a positive reputation.
I have been putting in a total of 7.5 quarts of Mobile 1.
That is probably because I put about 1/2 quart in the oil filter to pre-lube it up.
Does anyone else do that trick? If I don't do it, I usually get a hard-start and it takes a bit for oil pressure to level off.
Tony.
Old 03-29-2011, 06:12 AM
shotgunz's Avatar
I put the first 1/2 quart of oil in the filter too, but never exceed 7 quarts.
Old 04-02-2011, 01:55 PM
Steve_Uzi Steve_Uzi is offline
Steve_Uzi is starting off with a positive reputation.
Quote:
So True.... but I believe older 5.4 2v's used only 6 quarts of oil.. I know it doesn't apply to owners of the 3v 5.4. But I had a Stealership only put in 6 quarts - Well because they are stupid ...
Thankfully 1 quart low isn't going to KILL the engine and I found it the next day as I always check the Quality of work peformed by Stealership
So the service manager drove to my house and put the quart in as well as he gave me a $50 off coupon on next service
Old 02-20-2014, 09:23 PM
Sal1707 Sal1707 is offline
Sal1707 is starting off with a positive reputation.
what oil do most of yall use dino or synthetic?
Old 02-22-2014, 09:45 PM
papasmurf40's Avatar
papasmurf40 papasmurf40 is offline
papasmurf40 is starting off with a positive reputation.
Motorcraft 5w20 semi synthetic from Wally World(Walmart) is what I personally use but, I think any good quality brand name oil with specs the same as called for in the owners manual will work fine. Do use Motorcraft oil filters as they seem to be better than other filters.
I have to go to the US of A to get my oil as Ford doesn't sell Motorcraft oil other than at stealerships in Canada.
question about first oil change tim665214 6.7L Power Stroke Diesel 1 10-28-2016 01:46 PM
Oil Change, not draining?! HELP! mslopnick 1967 - 1972 F-100 & Larger F-Series Trucks 15 09-30-2016 04:44 PM
Oil Capacity and Dipstick Questions ALedbetter1 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 03-28-2015 06:17 AM
6.7L Oil Change concerns JustinRo2014F250 6.7L Power Stroke Diesel 15 04-02-2014 08:47 PM
Transmission Saga metalbender1 Excursion - King of SUVs 5 01-20-2014 11:58 AM
Tags
150, 1996, 2004, 2008, 54, 54l, capacity, engine, engines, f150, filter, ford, oil, quarts, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
