Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-20-2011, 09:46 PM
FordF350Superduty's Avatar
FordF350Superduty FordF350Superduty is offline
Garage is empty, add now
FordF350Superduty is starting off with a positive reputation.
How good is 4.9 L (300 CID) I6 engine?
Hi guys!
Have a question,how good is 4.9 L (300 CID) I6 engine?
Thanks.
  #2 (permalink)
Old 03-20-2011, 10:45 PM
dyingtolive's Avatar
dyingtolive dyingtolive is offline
1984 Ford F-150
dyingtolive is gaining momentum as a positive member of FTE.
It's the best. Arguably the best engine that Ford ever produced, and in the opinion of many, the toughest, most dependable, longest lasting (mine has 393,000 miles) that anyone has ever produced.
It has more low RPM torque than just about any other gas engine out there, and is probably the best gas engine available for towing, or for a work truck. To get a better towing/work truck engine, you'd probably have to go with a diesel. Now, in its stock form, it definitely won't get you anywhere fast, but it'll get you there just about every time without fail. And, with a little modification and the right gearing, the 300 will fly. Hell, there have been people that have done amazing things with these engines, building them to 300+ hp (Col Flashman), and some who have used them as drag racing engines. (The Frenchtown Flyer, look up ftf300 on youtube)
__________________
Jake
1984 F-150, 300 I6, 4 Speed, 4x4, .030 Overbore, Duraspark II conversion, 9" Rear Axle (Blown motor)
1985 F-350, 460, T-19, 5.13:1 Gears, 4 door
  #3 (permalink)
Old 03-21-2011, 10:02 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
1981 Ford Bronco
AbandonedBronco has a good reputation on FTE.AbandonedBronco has a good reputation on FTE.
Yup, what dyingtolive said.
One thing to keep in mind, however, is simply how much power they came with in stock form:
carb:
120hp @ 3000 RPMs
255tq @ 1400 RPMs
EFI
150hp @ 3400 RPMs
265tq @ 2000 RPMs
Lots of grunt down low, but people who get one and expect them to perform like a V8 are usually disappointed.
They take happily to mods though, that's for sure.... At least the carb version does.
__________________
1981 Ford Bronco. 300I6 Offenhauser DP Intake Holley 600 4bbl, 31" BFG A/T, NP435, 3.00 rear 9" EFI Manifolds. 2.5" high flow cat/muffler.
1984 Ford Bronco. 300I6 Offenhauser C Intake Holley 600 4bbl, 31" BFG A/T, NP435, 3.55 rear 8.8" EFI Manifolds. 2.5" high flow cat/muffler.
Supermotors Pics
  #4 (permalink)
Old 03-21-2011, 05:17 PM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
What do you mean by "good"? A bit of definition might help.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
"It'll put out what ever it puts out." fordman75
  #5 (permalink)
Old 03-21-2011, 05:36 PM
im2tall33's Avatar
im2tall33 im2tall33 is offline
ID CHAPTER LDR
im2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputation
in my opinion it is the best and most reliable engine ever!! and bullet proof too! and like Ab posted dont expect it to be a v8 but if you want a workhorse there isnt a better motor
__________________
Micah Munroe BIG BSer#2and Slackmaster #19
[font=Comic Sans MS][font=Impact][color=Black]Click to join the Idaho Chapter] 1994 F-150 4x4 300-6 5spd aka. money maker
Quote:
Originally Posted by BIGKEN View Post
Micah...the man...the myth...the legend!!!
  #6 (permalink)
Old 03-21-2011, 06:07 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
1994 Ford F-150
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
One of - the - best truck gasoline engines ever made.
Good engine for what it's built for.
If you want to get somewhere fast, however, you are - much - better off with a V8.
__________________
Rise and rise again..
until Lambs become Lions
Add me on FaceBook! https://www.facebook.com/bill.holsinger.5?ref=tn_tnmn
  #7 (permalink)
Old 03-21-2011, 06:39 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to all
I bought a used truck in 97 that has a 300 in it. I figured when the engine wore out, I would swap in a 6.9L diesel. More than 13 years later, that 300 still doesn't use any oil to speak of, *maybe* 1/2 qt between changes, most of which drips from the oil pan.......
I still plan to swap in a 6.9L diesel, but only after the 300 is completely worn out. At this rate, I'll die before the 300 does...........
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
  #8 (permalink)
Old 03-21-2011, 06:56 PM
im2tall33's Avatar
ID CHAPTER LDR
very true^^^ my dad has a 81 bronco with a 300 and its the original motor never rebuilt and it still runs great..although it does need other work.. i swear beefore these motors die the rest of the car will
__________________
  #9 (permalink)
Old 03-21-2011, 07:26 PM
billt28's Avatar
billt28 billt28 is offline
1986 Ford F-150
billt28 is gaining momentum as a positive member of FTE.billt28 is gaining momentum as a positive member of FTE.
The first 300 I had to rebuild, it had so many miles on it that I just tipped the block over and the pistons fell out. When you was driving down the road it sounded like a diesel. That was in 91. I still have that engine, cept now its got almost 3000 miles on it since I punched it out .060. That ought to tell you the reliability of these engines. Just a word of caution though, be careful of some that was produced in the early 80's, they have the phenolic timing gears in them and they like to shred.
__________________
'86 F-150 4X4 good old 300 recently punched .060 over
  #10 (permalink)
Old 03-21-2011, 11:01 PM
Thank you,guys!
Looks like 4.9 very reliable engine!
  #11 (permalink)
Old 03-21-2011, 11:39 PM
west6772 west6772 is offline
1995 Ford F-150
west6772 is starting off with a positive reputation.
In general, straight six engines kick ***! Most heavy duty diesel engines are inline 6 configuration for a reason. They have fewer rotating parts, no lateral forces on the cylinder bore, and take up less space than a similarly displaced V8.
My 1995 F150 has a 300 I6 with over 240,000 miles on it and runs great.
  #12 (permalink)
Old 03-22-2011, 12:19 PM
The biggest weakness a 300 has, is the factory cam gear.
When they were made from metal, they lasted dern near forever, but people hated the noise made by them.
They switched to several varieties of plastics trying to keep the gears quiet. Worked pretty well, but people complained when they went bad.
The latest variation seems to last around 200K on average before needing replaced. Gives a pretty good excuse for pulling the cover and replacing the front seal that has likely started leaking by then anyways, then go for another 200-400K.......
I have no clue what type of cam gear is in my engine. As I said, I bought the truck used, for a rather cheap price, and figured I would run the 300 till it was finished and swap in a diesel. A couple weeks after I bought the truck, I found a work order for the engine rebuild. It cost more than I paid for the whole truck. If they really did everything listed on that work order, this engine should have another 200K (at least) life left in it. I know I have put over 100K on it, with little more than basic PM service.
After finding that reciept, I pretty much quit looking for a diesel to swap in. I still casually keep an eye out for a deal too good to pass up, just to keep up with current pricing trends......
You may wonder why I want to swap a diesel in after the 300 is wore out. It's simple really. What else will give me the same kind of low RPM torque, but in higher quantities, without reducing the MPG? I get 12-17 MPG currently, depending on load and conditions. The same load and conditions should yield 15-20 MPG with a diesel. Maybe even more with a turbo, and my rather conservative driving habits.
That's another great thing about the 300, with the ever increasing cost of fuel, it can teach a person to drive in a fuel freindly manner. Mashing the skinny pedal doesn't really do much, aside from consuming extra fuel. Learning to use a lighter throttle foot will get you there nearly as quickly, but with a lot more fuel left in the tank....... This is especially true of the older carbed 300's.
__________________
  #13 (permalink)
Old 03-22-2011, 12:37 PM
1981 Ford Bronco
I can attribute to that. I replaced my cam this winter with a Comp 260h. In the process, I put in a set of steel timing gears for durability. I imagine they'll last forever, but I also imagine I'll...eventually....get used to the sound.
__________________
Supermotors Pics
  #14 (permalink)
Old 03-22-2011, 02:29 PM
1984 Ford F-150
What do those steel timing gears sound like?
__________________
Jake
  #15 (permalink)
Old 03-22-2011, 02:39 PM
1981 Ford Bronco
I'll have to get a video recording of it, but they definitely have an audible howl to them. It's not bad, just used to my engine being a bit more quiet (which is probably why they experimented with getting rid of them in the first place.)
__________________
Supermotors Pics
Tags
1990, 300, 300cid, 49, cid, engine, f150, good, i6, liter, power, pump, specs, straight, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
