352 to replace 390 help
My 74 F250 had a wristpin come loose and gouge the cylinder about .040" on one cylinder. I have been hunting a good block and bought what I thaught was a 360 in junkyard. When I got it home tore it down and found it to be a 352. The 352 pistons and crank are in good shape, block could use a honeingbut that is in good shape. I have 2 reman heads for the 390 and a 4 barrel intake off the 390. What can I do with the 352 to make it run without it being a gutless wonder without excessive boaring? Or would I be better off getting the 390 block repaired? I never ran a 352 and dont know anything about how they perform or what can be done with them. Any imformation would help, Please.
I have been looking for a FE block over 4 months and I was suprised to find an engine that wasnt frozen fast even though it was only a 352. Seems there arent too many FE blocks left in my area. I even have a 460 boared .040 over completely rebuilt I was ready to replace my 390 with. The only hesitation I had was that my C6 transmission for the 390 was rebuilt and I hate to waste it.
I dont know much about pressed sleaves I am looking for a long life repair would a sleaved block last as long as a stock boar in the 352? I am looking for recomdations from you guys on what would be best I was even considering the 380 build mentioned on another thread but dont have any idea where to find 390 pi rods or what that motor would be like. With only 10 cubic inches difference from the 390 would there be much difference?
The last sleeve I had put in an engine, a 1967 390GT with the same wrist pin problem as yours, went 78,000 before I sold the truck 8 years ago and I know the truck is still running fine because I see it every couple of weeks and the guy can't change spark plugs without help. Is that long term enough for you? Hell a lot of racing engines have sleeves from the get go.
You can get away with hand tools except for the low reverse drum....Spring compressor needed for about 60 bucks and 20 bucks for a set of Lock ring pliers
Get a manual and a video. Autos are easy do not be afraid
Lonnie
you will only lose about 25lbs torque and maybe 20hp...MAYBE...over a 390 with off the shelf pistons do to better efficiency
the K&B 243 has a 1.84 ch..yet it has a raised circumference dome that they dont count that is .018 tall around the top
Add this up...360 ford
KB 243 piston...ch..1.840 + .018 dome..(not listed but a call to K&B will verify)
this will give you a ............. 1.858 CH
add...3.5 crank....divide by 2 = 1.75 crank
add.......rod ...........................6.54
You get a stack of 10.148
take .015-.020 off the deck....
see where this is going ??
way more efficient engine than a off the shelf piston for the 390 or 360 (cheap)
Usually you have almost no power loss to the 390 with this piston
the pin is .009 larger if i remember right.....but you must have your rods rebuilt and bushed already ....so your machinest can bush the rod for the larger pin
the KB 243 is full floating so no issue there..I have built 4 of these and they are Great engines and use LESS fuel than the 390 with about the same power
and a strong piston to boot !
last set I bought were about $250.00 I think
The valve reliefs are radial and work with the 360-390 head as long as your only using a .550 lift cam or less
The total volume of the KB243 is only 6.5cc
So a 9.3-9.5 compression is doalble with a 360 and the proper Cometic gasket
I know Out of the box thinking...it also works with a 390 ford..IF you mill .048 off the deck..If i remember right KB says the deck is .318 thick..and it is safe to go .195 on the deck..........................PER KB on a non boosted engine ..for a 10:1 .....390
Just my thought
Sorry for rambling on
Lonnie
TEX001
34
08-09-2020 07:44 AM
wildwindjerry
04-24-2015 09:56 AM
FchasE
25
03-05-2011 11:52 AM
1975 f150 360
10-17-2003 12:35 PM
specialz
04-12-2003 11:23 PM
