horsepower rating of 351W ? - Ford Truck Enthusiasts Forums
Old 03-20-2011, 07:37 PM
redwoodlogger's Avatar
redwoodlogger redwoodlogger is offline
redwoodlogger is starting off with a positive reputation.
Hello all, I've got a 1980 F-150 with the 351 Windsor. How do I find the horsepower and torque ratings for this motor ? I've been told that certain 351's are highly sought after for building up. And, some of them have special heads that are valuable ? Thanks
Old 03-20-2011, 07:53 PM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.
Your HP and torque figures will vary depending on the year and fuel setup. As described an earlier thread today, 302s and 351s have shared the same heads since the late 70s. What's more important is getting right head castings. If your heads have E5TE, or E6TE, get rid of them. They don"t breathe very well. The E6s are worse, but you can better than both. E7TEs breathe much better. Ideally you want to find something that has F#ZE on them. Those will be a variant of the GT40 heads. These heads will also be marked with a GT40 on top. Keep in mind that the bolt holes on a 351 head are larger than a 302, so if you get heads from a 302 those holes will need to be enlarged.
Old 03-20-2011, 07:56 PM
BTW, you may want to reach out to a guy with the screename of Conanski. I think he usually views the 87-96 and the 302 forums. He knows as much as anybody on these engines.
Old 03-21-2011, 02:24 AM
re: HP rating of 351W
Thanks for the reply
Old 03-21-2011, 02:35 AM
Anafiel's Avatar
Anafiel Anafiel is offline
Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.
Old 03-21-2011, 06:41 AM
hp rating of 351w
Thanks , I already found it, great article
Old 03-21-2011, 10:04 AM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
here is one that I ran accross a while back
Engine_Specifications
Old 12-15-2014, 02:20 PM
HenryBaker HenryBaker is offline
HenryBaker is starting off with a positive reputation.
If i were to purchase a remanufactured 5.8 to replace my old and tired engine, should i expect the same stock hp and torque? I am new to all this and my engine is just tired and slow and sluggish. Looking to start re-vamping the beast. Any suggestions?
thanks
Old 12-15-2014, 02:41 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
1980 would not have had a 351w stock. It would be a 351m. So either it's a M or the windsor was swapped in.
Old 12-15-2014, 02:43 PM
its a 95 f150.
Old 12-15-2014, 02:48 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
A stock remanufactured engine is just that. It drops in place and has the same specs as the stock engine had. You can get remanufactured engines in different flavors from different rebuilders though, if you have the money to spend. You need to be careful though, you really can't hop the engine up too much since you have a 95 and it's fuel injected.
Old 12-15-2014, 02:53 PM
Thanks for your reply. I am new to all this so excuse my Green-ness. Would I have to replace transmission as well when replacing stock motor? A friend of mine has told me i would probably need to replace rear end, and tranny. Sounds like a lot of work. I am wondering where i should start, I have found remans of the 5.8 for about 1500 bucks. I have also found a used 5.8 with about 78000 miles on it for about 1000 bucks. Just researching options before I have a game plan to revamp my 95 f150. I love the truck, but man its slow and horrible on fuel. I would like a smoother run if its gonna be this thirsty anyway.. Any suggestions will help immensely!
Old 12-15-2014, 03:01 PM
Franklin2's Avatar
If you have a 5.8 in it already, a 5.8 made for that same year should drop right in place, no need to change the tranny. If it's a automatic I would change the front seal before putting the new engine in place.
If your engine uses very little oil, doesn't smoke or make odd noises, I would not necessarily swap it out because it doesn't have any power.
Old 12-15-2014, 04:11 PM
Oh thanks. ok well thats true it doesn't smoke or leak. It's just tired and slow. What could I do to improve its performance? without replacing. I have replaced spark plugs/wires. Fuel filter, throttle body cleaned. replaced some exhaust valve.
there is one noise that concerns me. its a chug-a-lugging helicoptor, almost metalic sound. i epecially hear it while going uphill, when it feels like it struggles. it has headers and flowmaster exhaust and this sound is easily heard over the exhaust. anyone know what it could be? bores large from being an old engine? some sort of seal?
thanks
Old 12-15-2014, 05:03 PM
Would a rebuild kit with gaskets and all that be something I should try? Other than that I am wondering what engine work will be required. I can do some work on my own but don't have the space to really dig in and learn how to work on my truck. I don't want to be wasting money having mechanics look into certain things.. I guess I am wondering what are a few key things i should get taken care of/looked into before I consider a new engine?
Ford 360 FE davelong667 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 30 01-30-2017 12:36 AM
351 Johno.h 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 05-10-2016 08:55 AM
460 or 351? vinnydiesel27 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 03-18-2016 09:46 PM
351 w stroker kit advice 95-4x4-f250 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 10-07-2014 06:04 PM
More horsepower/torque 351W 96 CooperF350 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 09-21-2014 01:49 AM
Tags
150, 1985, 350, 351, 351w, 86, 95, ford, horsepower, hp, rating, ratings, specs, truck, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
