how to drop gas tank - Ford Truck Enthusiasts Forums
Old 03-20-2011, 02:45 PM
rickthefix rickthefix is offline
rickthefix is starting off with a positive reputation.
i have 2 f150's, but never worked on explorer. co-workers nephew dropped off his 95 explorer yesterday for me to replace the fuel pump & filter. i've dropped the tank on my 87 f150 & a few other cars, but this one looks a little more involved, less room to work with. i don't have access to a service manual. anyone want to help a FTE man out with destructions or a link to them?
TIA,
Rick
Old 03-20-2011, 03:17 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
When I dropped my tank, I used the instructions in Chilton's and did fine. Autozone has a free version of Chilton's on their site if you are willing to register with them.
Old 03-20-2011, 05:43 PM
tnx mr shorty,
i looked just little more on this site & found a thread about dropping the tank far enuff w/o removing the fill lines. that's what i did & worked good. also replaced the filter, already had the line removal tool.
now that it will start, i noticed it has the CEL lit up. how do i put this 95 into diag mode to check the CEL code?
Old 03-21-2011, 08:10 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Old 03-21-2011, 10:12 PM
found the test plug right after posting the question & it is identical to my 87 f150, so was not a problem. has code 113 & already have a space ACT sensor to install. only, it's not my explorer & the kid picked up up last night, he knows what's wrong with it & that i could fix it for him if he wants.
thanks for the replies
2010 Explorer, gas guage drops to empty PSWII60 Fuel Injection, Carburetion & Fuel System 0 04-10-2016 02:21 AM
Dropping front gas tank minnesotafisherman 1987 - 1996 F150 & Larger F-Series Trucks 26 01-28-2016 02:21 PM
Need powerful alternator on F250 Milwaukee1979F150 1987 - 1996 F150 & Larger F-Series Trucks 25 12-12-2015 02:05 PM
Fuel Pump Question xjoedirt55x Explorer, Sport Trac, Mountaineer & Aviator 3 01-19-2008 08:02 AM
Rear fuel tank doesn't pump, 87f150xlt 1987 - 1996 F150 & Larger F-Series Trucks 15 11-09-2004 12:19 AM
Tags
1987, 1997, 94, 96, bronco, drop, dropping, expedition, explorer, exsplore, f150, fazer, ford, fuel, gas, tank, tanks, yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
