truck cab interchange?
#61
#62
For sure on the body parts. I am not a 4x4 guy but I was thinking all the ttbs's were the same. Leaf vs coil perhaps though. Someone will confirm/deny that for you though.
#63
#64
I'd also mention if you want to stick with the 80-86 style or if you don't care and would accept the next gen.
#67
Hey, think that was a different fellow from a year ago on the 4x4 question. Good to know though - the trucks I gravitate towards are generally 2wd so limited exposure.
#68
But having this kind of information in the archives for the people gere via the Google searches is a Good Thing.
#70
Hi,
I have a 1981 F100 2wd that has a bent frame. I want to put the cab/front nose from the 81 on my 1987 f250 4x4 frame. Both are standard cab. The f100 is a short bed, the f250 is a long bed. I’ve seen a bunch of info on this thread about newer cabs on older frames, but not as much on older cabs on newer frames. Will everything mount up?
thanks in advance.
thanks in advance.
#71
UH, welcome to FTE.
I think there was a post on this not long ago, last week maybe?
Any way IIRC the cab & front clip (nose) of the 81 should bolt to the 87 frame but ......... the bumper will not.
If you look at the front frame parts they are different so the bumpers will not swap.
Now someone said you could cut the ends off each frame and weld them on the other frame.
As for the bed part the change is all behind the cabs between the 2.
Dave ----
Dave ----
#72
I found a nice 86, with title, in NC. No front clip, engine or transmission. Took the cab mounting bolts out, disconnected brake lines, steering column. Jacked the cab up high enough to pull the frame out from under the cab. Set the cab back down on a trailer, for later installation on a 4x4 frame. Now the cab has a NY title.
#73
#74
I dint think the columns swap because the dash & frames are different. Give a quick look when the column bolts to the dash frame think you can see the difference.
Now I like the CV frame swap to the 81 body. Look up member Monkey1 I think it is as he has don't this swap to our year truck and the 70's.
If you do a Youtube search on this you will find this can be done a few different ways. I think the easy way is frame for frame.
Harder is use the frame, floor & fire wall / dash of the CV and cut the floor & fire wall out of the F100. You then have the fire wall & dash of the CV in the cab of the F100.
Dave ----
#75
Hi,
thanks in advance.
thanks in advance.
yes. Same 4 bolt pattern for the cab and the 2 bolts for radiatior support.
Bumper is a DIRECT bolt on
Truck Guy99
10-21-2016 09:30 AM
three on the tree
03-09-2016 10:13 PM
nbart3845
13
03-07-2016 08:18 PM
1997, 2000, 86, 87, berlincam86, cab, cabs, enterchange, f150, f350, ford, frame, interchange, interchangeable, truck
