55 Cowl Vent Seal suggestions
Everyone,
As I was searching the forum for tips on putting a cowl vent seal on it seems like it is a PITA on these 53-56s(or every truck for that matter).
It seems like I need about another 3/4 inch on this thing to where I wouldnt have to stretch it out to wrap all the way around. (Dang thing is all twisty) Oh well. I saw Sam's suggestion he used "clothes pins". That seems like a good idea. I was trying to use some small metal wood clamps.
Any other suggestions???
Thanks
Patrick
Thanks
Patrick
Everyone,
Thanks
Patrick
Thanks
Patrick
Sam
on
The vent on my 50 works just fine and doesn't appear to leak though I have only had it out in the rain twice. Maybe I should not mess with it or should i go ahead and get another gasket and put that in??? Opinons welcome and if anybody has a picture of the gasket installed with tips it would be welcome.
jim
jim
I have never tried the boiling/heating up method..but would certainly give it a try.
I got a seal ,along with alot of other parts when I made the truck purchase..and like a few others on here, that was well over 8 yrs ago. It sat brand new in an un-opened/sealed bag during that time,when I got to the point of installation..I fought dry-fitting it for at "least" 2 hrs.It was too stiff and twisted as mentioned above., Always seemed to be about 3/4-1" short.
I ended up buying a new one from mid-50, came in a week later. It was so soft and easy to work with..I could have put it on with my feet.10 min tops install time. The difference made me rethink the remaining seals..vent glass,the new hollow door seals etc;..
Don't overlook the trial/dryfitting before you start applying glue.
I'm thinking I may try the boil/heating method on the wing glass seals before re-ordering after reading this post.. Thank's!
I remember as a kid putting car models together: when it came time to put the tires on the wheels, the directions said to soak the tires in hot water for several minutes before slipping the tires on the rims... good advice then and still good today for all things rubber...
Like cmoritz, I also stated mine was twisted and seem a little short. I might try the boiling water method and if it still seems short and too twisted I might just buy another one like you.
Patrick
