coolant smell in cab - Ford Truck Enthusiasts Forums
Old 03-19-2011, 11:46 AM
daddogg daddogg is offline
daddogg is starting off with a positive reputation.
Hi guys. I am in San Diego, my son and his 2001 f150 gas v8 are in Colorado. When I am there I help him work on his vehicles, but this is an attempt to guide him long distance. There is a coolant smell in the cab. The first thing I think of is a leaking heater core, ant told him to check for wetness on the floor. While I am waiting for him to come back about that I am asking you guys if there are other possibilities for the symptom? dd
Old 03-19-2011, 12:46 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
9 times out of 10 your diagnostic is right on. Most likely the heater core.
Old 03-19-2011, 01:07 PM
brokenleg brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
Heater core time.
Old 03-20-2011, 05:35 PM
Dave G. Dave G. is offline
Dave G. is gaining momentum as a positive member of FTE.
Probably every situation is different, but my '99 4.6 has had the Prestone aroma for almost 3 years. No visible leak, coolant level hasn't dropped, heater works fine. It only takes a couple of drops for the blower to pick up the smell and fill the cab. If you have a day to kill just change it and the hoses.
Dave
Old 03-20-2011, 06:04 PM
thanks for comming in on this, looks like I'll have a fun visit next time I go to Colorado. How tough is it to do the heater core on that 2001 f150? I'm guessing the new core will be 50 to 100$ ?? any special tools needed? I'll tell him to mate the in and out hoses at the firewall for the time being to be able to drive without losing coolant dd
Old 03-20-2011, 07:42 PM
That truck should have quick connect hose ends. If so, the hoses would be problematic to join together and bypass the core. If there is no visible leaking into the cab, and the coolant level isn't dropping that you can see (or him), I'd leave it be until you can work on it. A little early in the spring to disconnect it. The a/c lines may be in the way. If so, the refrigerant would have to be removed before disconnecting the lines.
Dave
Old 03-20-2011, 07:43 PM
Dave
Old 03-20-2011, 08:35 PM
tbobb tbobb is offline
tbobb is starting off with a positive reputation.
heater core
I had this problem, yes, heater core. It's about $800 to fix, dash has to come off. Since it's not cold now, he can cut the line in the engine to stop flow to heater core. This stops the leak, but you'll have no cabin heat. I can get away with this in Arizona.
Old 04-03-2011, 02:08 PM
seleberry seleberry is offline
seleberry is starting off with a positive reputation.
heater core..??
2001 F-150. Heater works fine, defroster doesn't work well, although lots of air blows thru windshield vents. A/C works fine. No leaks inside or out.
COOLANT smell is killing me. Is this the heater core?
Chilton makes the work sound tedious but not terribly tough (besides the A/C discharging). But other articles saying steering column, steering wheel, has to come off.
Any ideas/advice/thoughts?
Thanks,
SB
Old 04-04-2011, 07:16 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Thanks,
SB
I'd say yes, it is the heater core.
No need to discharge the A/C, the dash comes completely out, and this also means that you're dropping and removing the steering column as a complete unit-steering wheel and all. I've done a few of them, and I can do the complete job in approx 5 hours now. The first one took me nearly 12 hrs.
JL
Old 04-04-2011, 10:05 AM
Thanks JL. Exactly what I was wondering
Old 04-04-2011, 01:05 PM
paker paker is offline
paker is starting off with a positive reputation.
Youtube has a shortcut video. Basically, accessing the heater core by cutting the plastic panel behind the glove box. See if it applies to your year.
Old 04-04-2011, 06:46 PM
Thanks. I'll check it out
EVER HEAR OF THIS LITTLE TRICK? 72CC428 1967 - 1972 F-100 & Larger F-Series Trucks 8 12-04-2016 06:29 PM
Fuel in coolant ? BigRed1Ton 6.0L Power Stroke Diesel 6 01-29-2016 04:46 PM
'04 6.0 advice needed.. schlepprock250 6.0L Power Stroke Diesel 12 05-31-2015 11:37 AM
95 f150 bad slave cylinder? big-ugly 1987 - 1996 F150 & Larger F-Series Trucks 5 04-23-2011 06:44 PM
timing cover coolant leak? Green_Monster 1987 - 1996 F150 & Larger F-Series Trucks 6 03-10-2003 02:14 PM
Tags
2004, 2005, 54, ac, antifreeze, cab, coolant, defogger, f150, f250, ford, leak, odor, smell, truck, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
