Intercooler Pipes
Email this guy smokin-69@msn.com, he builds ic pipes for the obs for around $200 shipped to ur door. just tell him what u have and he will make them for you. i found it here so you can see the kinda work he does OBS 7.3 IC Pics - PowerStrokeNation .
uhh kinda the ic pipes feed into two spots, 1) the intake plenums and 2) the tubro right above the intake houseing. if you look at ur stock y-pipe u will see i connects both of those together, but the ic has a pipe for each to put cold air into your turbo and plenums. heres kinda what im talking about lol a pic is worth a thousand words i guess OBS 7.3 IC Pics - PowerStrokeNation
on
1 Post
yea i wonder if they are, maybe finally somebody figured out theres a huge need for obs ic pipes and they could make a buck off it.
Actually for those who don't know what the intercooler does, it cools the air that is super heated by the turbo. The cooled air is more dense so more fits into the cylinder for compression. Also, the cooler air has more oxygen which makes for more efficient cumbustion, making more power. Know for the part I don't understand. Why do the powerstrokes have the spider? The big diesels push the air out of the turbo, through the heat exchanger, into the intake. Will that work ok on our engines?
