Blown diff or just seals.
03-03-2016, 07:17 PM
on
03-03-2016, 07:23 PM
on
if you hear the squeak squeak squeak then take a good look at your u-joints
and yes your pinion seal needs attention
03-04-2016, 08:35 AM
on
Ditto on the u-joint.
You should not see any wear in the bearing surfaces of the joints.
If you have 1 bad one, change them all out. The rest will not be far behind.
03-07-2016, 07:38 AM
Also check your differential oil level, that's not a small leak. If you didn't catch it in time low oil may have wrecked your bearings.
PapaBearYuma
35
10-24-2016 03:39 PM
roadrash63
Offroad & 4x4
10-19-2014 06:50 AM
Pablo-UA
02-08-2014 03:17 PM
crazy96863
11-26-2012 12:22 AM
ATC Crazy
Virginia Chapter
09-18-2008 11:06 PM
