Removing The Wiper Cowl
Mother's 'Back To Black'.
Mothers® Back-to-Black® Heavy Duty Trim Cleaner Kit
I'm going to get this and try it. My truck only has 15,500 mi. but it sits outside, and most of the trim is starting to gray. I also get some kind of fungus on some of the rubber parts that pits the rubber. I'll use a Scotch Brite pad to scrub with the 'Back To Black'.
When looking at the trim pieces, I noticed there's more than just the wiper cowl. There's the door handles, bed trim, front grill, and even the side mirrors. Would make sense to do all together IMO except to paint something like the door handles is scary without knowing how to take those off. Is it common for people to touch up all the heavy duty plastic trim pieces to black?
If you use a terry cloth rag , get it soaked up , and keep it in a zip lock , it works great , even use a scrub brush coated with it for tough areas .
The 3M stuff is thick and doesn't run off .
I got some professional detailer "black trim" restorer made by 3M I use it on everything but the cowl , was just too much work and faded gray .
Glad I found this thread. I was planning on taking mine off this spring to repaint them. I just replaced the corner moldings since the originals disintegrated years ago. Now it's even more obvious how badly faded my cowl covers are. I might use the Mothers Back to Black on things like the mirrors, door handles, bed rail caps, etc. If the cowl panels are that easy to take off, and they're so faded, I don't think the Mothers will be enough.
Thanks! I was quite pleased with the result.
I used Dawn dish soap and a scrub brush to clean the plastic, allowed it to dry thoroughly, then applied several light coats of paint.
I didn't remove the washer nozzles because I was afraid the ten year old plastic might be too brittle, but I had no problem with clogging them. The new rubber pieces make a huge difference as well.
How easy was it to remove the washer nozzles once the covers are off? Are they just held in by clips? I thought of the same thing and thought of either removing them, or masking them off.
Scott in TX
10-13-2017 10:00 PM
