Removing The Wiper Cowl - Page 2 - Ford Truck Enthusiasts Forums
Old 07-24-2014, 02:45 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Quote:
Originally Posted by 1saxman View Post
Mother's 'Back To Black'.
MothersŪ Back-to-BlackŪ Heavy Duty Trim Cleaner Kit
I'm going to get this and try it. My truck only has 15,500 mi. but it sits outside, and most of the trim is starting to gray. I also get some kind of fungus on some of the rubber parts that pits the rubber. I'll use a Scotch Brite pad to scrub with the 'Back To Black'.
I did the back to black thing for quite a while , and then when I had my windshield replaced , and saw how easy the cowl came off , I took it off and painted it with special trim black paint (got it at Autozone ) and also replaced the little rubber seal strips on each end , and took apart washers and cleaned .
Old 07-24-2014, 06:15 PM
texasJ texasJ is offline
texasJ is starting off with a positive reputation.
When looking at the trim pieces, I noticed there's more than just the wiper cowl. There's the door handles, bed trim, front grill, and even the side mirrors. Would make sense to do all together IMO except to paint something like the door handles is scary without knowing how to take those off. Is it common for people to touch up all the heavy duty plastic trim pieces to black?
Old 07-24-2014, 06:44 PM
Quote:
I got some professional detailer "black trim" restorer made by 3M I use it on everything but the cowl , was just too much work and faded gray .
If you use a terry cloth rag , get it soaked up , and keep it in a zip lock , it works great , even use a scrub brush coated with it for tough areas .
The 3M stuff is thick and doesn't run off .
Old 07-24-2014, 07:00 PM
Wow thanks for the tip. I think I found it. Is it 3M Bondo Restore Black? What kind of paint and process do you use to do the cowl?
Old 07-24-2014, 11:25 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
You pretty much have to use a small brush on the cowl because of the pattern on it. Also, pre-cleaning is the trick. Drugstore alcohol is good. This would be required before painting too because of the presence of silicone from using tire/trim treatments in the past.
Old 02-13-2016, 02:53 PM
lgallentine lgallentine is offline
lgallentine is starting off with a positive reputation.
Quote:
Originally Posted by dgndngrngr84 View Post
No problem, I just remembered too that there is a bolt in the center which holds the passenger section down. I think its 7/32.
Its actually 7 mm.
Old 02-14-2016, 03:20 AM
wrvond's Avatar
wrvond wrvond is offline
wrvond has a good reputation on FTE.wrvond has a good reputation on FTE.wrvond has a good reputation on FTE.
Did mine using this:
Old 03-05-2016, 03:55 PM
Pgh Rebel's Avatar
Pgh Rebel Pgh Rebel is online now
Pgh Rebel is gaining momentum as a positive member of FTE.Pgh Rebel is gaining momentum as a positive member of FTE.
Glad I found this thread. I was planning on taking mine off this spring to repaint them. I just replaced the corner moldings since the originals disintegrated years ago. Now it's even more obvious how badly faded my cowl covers are. I might use the Mothers Back to Black on things like the mirrors, door handles, bed rail caps, etc. If the cowl panels are that easy to take off, and they're so faded, I don't think the Mothers will be enough.
Old 03-05-2016, 08:35 PM
1saxman's Avatar
wrvond; that looks great!
Old 03-07-2016, 05:33 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
Yes it does. A really easy project, that makes a great visual improvement. I sprayed mine not too long after my previous post-plastic paint. I did remove the wiper spray nozzles so they wouldn't get clogged.
Old 03-07-2016, 09:29 AM
wrvond's Avatar
Thanks! I was quite pleased with the result.
I used Dawn dish soap and a scrub brush to clean the plastic, allowed it to dry thoroughly, then applied several light coats of paint.
I didn't remove the washer nozzles because I was afraid the ten year old plastic might be too brittle, but I had no problem with clogging them. The new rubber pieces make a huge difference as well.
Old 03-07-2016, 07:34 PM
Pgh Rebel's Avatar
Quote:
How easy was it to remove the washer nozzles once the covers are off? Are they just held in by clips? I thought of the same thing and thought of either removing them, or masking them off.
88 ford cowl 88_F0RD 1987 - 1996 F150 & Larger F-Series Trucks 1 05-11-2016 09:04 PM
Cowl removal? fordboy300 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-21-2015 07:17 PM
cowl vent installation questions drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-12-2015 07:47 AM
93 wiper motor removal 1998Ranger25L153CID Ranger & B-Series 3 04-20-2015 08:16 PM
Cowl Removal sconut1 1987 - 1996 F150 & Larger F-Series Trucks 9 10-04-2007 06:51 PM
Tags
05, 1986, 2006, 2008, 4x4, 60, cover, cowl, cowling, f150, ford, ranger, remove, stx, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
