2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Help w/ Buying 2007 Expy
Old 03-16-2011, 11:58 PM
crn808's Avatar
crn808
crn808 is offline
I am looking at buying a 2007 Expy 4x4. It has 59k miles runs and drives nice.
anyone have anything that I should look out for or be concerned with?
thanks for you help
Old 03-17-2011, 12:16 PM
function12's Avatar
function12
function12 is offline
Not sure if the 4X4's had the rear air shocks but if they did make sure the compressor is not cycling a lot. Can be very costly to replace. If you are buying from a dealership you might see if they will replace spark plugs, fuel filter, and transmission service. Also, ask the dealer for the door keypad code if equiped.
Old 03-17-2011, 08:20 PM
mtondreo's Avatar
mtondreo
mtondreo is offline
crank the wheel all of the way whil driving and listen for popping (your listening for sway bar ends). watch the speed up/down in the windows (watching for regulators). make sure the TPMS light is not on (looking for bad stems/bands). run the ac thru the different modes - panel, floor etc (listening for blend door problems); check rear as well. seat heaters if equipped. check for tailgate rust. will probably need a fuel filter now also if the previous owner did not do it. other than that-enjoy. Mine had a lot of the above issues, but the price reflected it. All fixed now and absolutely loving it - not even sure if I will go back to a truck again now. Hope this helps, Mike.
Old 03-17-2011, 08:47 PM
Jigger2020's Avatar
Jigger2020
Jigger2020 is offline
Received 5,155 Likes on 1,688 Posts
crn808 send us some pics, what color is it, welcome to the club.................
Old 03-27-2011, 05:48 PM
crn808's Avatar
crn808
crn808 is offline
thanks for the input, I got a 2007 XLT 4x4 with 59k miles the other day.
Old 03-27-2011, 06:01 PM
Jigger2020's Avatar
Jigger2020
Good for you man, welcome to the club!!!!!!!!!!
rexpedition99
26
04-02-2014 06:53 PM
87TxBronco
1997-2006 Expedition & Navigator
08-15-2011 07:34 PM
Katabe221
04-18-2010 11:09 AM
laz_68
12-14-2008 11:37 AM
cecoen
Car/truck Buying Advice
09-02-2006 02:45 PM
Quick Reply: Help w/ Buying 2007 Expy
