output shaft seal replacement - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 03-18-2011, 08:27 PM
high ho silver's Avatar
high ho silver high ho silver is offline
high ho silver is gaining momentum as a positive member of FTE.
Question output shaft seal replacement
02 Tribute (Escape's sister) has been leaking tranny fluid from the driver side seal where the CV axle shaft goes into the tranny. My question is this. What does the metal retainer looking plate do that covers the seal? This will be the second time I have replaced the seal and I totaly trashed the retainer plate on the first change and I am thinking now that maybe it has a purpose. (the replacement seal didn't come with one) When I push up on the shaft next to the seal, it appears the seal is now larger than the shaft causing fluid to leak out. Sort of like the seal opening has been wallowed out. Any help will be appreciated. I will start tearing it apart in the morning.
Old 03-19-2011, 07:25 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
Quote:
Probably just to keep debis from damaging the seal. Just like a radial ball bearing might either have seal(s) or shield(s).
Old 03-19-2011, 07:38 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
What wtpski said.. a seal 'protector'. If the seal is 'wallowed out', I would check the radial play in the output shaft. It should not wobble around very much, if at all. If it does, you may have an internal problem. Hope that it was debris that made the seal fail and wear prematurely.
tom
Old 03-19-2011, 06:22 PM
Thanks guys...that is what I had originally thought and did not worry about it at the time. I got the new one in and test drove it. So far no leak. My old seal looked like I may have damaged it a little sliding the axle shaft back in on the first install. This time I greased the new one up a little to keep it from trying to roll inward while installing the shaft. Hopefully the problem is gone.
Old 03-19-2011, 10:54 PM
There is a support bushing behind the seal. The seal/half-shaft/bushing has been a major cause of leaks that started in '09MY and continues even today!
Replacing a shifter shaft seal on a 1971 C6 transmission oleredford 1967 - 1972 F-100 & Larger F-Series Trucks 7 07-31-2014 07:33 PM
Rear main seal replacement? Donordad Modular V10 (6.8l) 7 07-08-2013 08:06 PM
BW 1356 Rear Seal bradleydm Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 05-29-2011 12:33 AM
tranny tail shaft seal blowing out LeroyB3000 Ranger & B-Series 4 03-20-2010 02:53 AM
How to replace front seal on FMX tranny epos48 1961 - 1966 F-100 & Larger F-Series Trucks 3 06-19-2005 11:09 PM
Tags
352, 93, case, explorer, ford, front, hoe, leak, leaking, main, output, replace, seal, shaft, transfer, transmission, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
