Warm Weather Drivability Issues - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 04-17-2011, 11:44 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Originally Posted by TX92F150 View Post
I bought an Powertrain Control/Emissions Diagnosis manual (my FSM didn't cover the emissions), and think I've found my fix.
There is a pink/tan plastic line coming off the TAD soleniod that should run to the diverter valve. I saw the line on the solenoid, but nothing near the valve. I traced the line around behind the manifold (it runs with some others in corrugated plastic conduit) and couldn't find the other end.
So, I disconnected it at the solenoid and blew air through it with an extension line, and listened for air escaping. I found the end of the line inside the corrugated plastic conduit running along the RH valve cover. It was open to the atmosphere.
Had this ever been hooked up? If so, how long since it was? Did I find a manufacturing/assembly defect? Had someone at the plant or a dealership accidentally broken off the end of the line, and just tucked it inside the conduit to hide it instead of fixing it? I'll never know for sure.
Anyway, I bought a rubber connector nipple and an elbow, and hooked it up like the service manual described. We'll see if it makes any drivability improvement.
Any comments or feedback?
Thanks!
JD
Great find. Hard to say what lead up to this situation.
Faulty IAC or vacuum leak??? 88XLTLariat 1987 - 1996 F150 & Larger F-Series Trucks 2 05-26-2016 06:28 PM
Warm weather! Back to the Project! 86 f150 351w chillman88 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-23-2015 04:55 PM
98 F-150 4.6L Misfire issue ! arod79sae 1997 - 2003 F150 9 06-10-2013 12:49 PM
P0405 Code (??) ncg45 Modular V8 (4.6L, 5.4L) 0 06-07-2011 09:39 AM
Oil Consumption -- All of a Sudden thollist Modular V10 (6.8l) 9 08-05-2009 10:07 AM
Tags
1992, 327, 58l, code, driveabilty, expected, f250, ford, google, higher, lever, lower, manual, position, problems, trouble, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
