2000 EB Stalls when put in drive but works fine in Reverse
Hey all,
I ran out of gas the other night and when I filled up the Truck it started right away but when I put her in Drive she stalls.. If I rev it and through it in drive still stalls.. BUT I CAN DRIVE IT FINE IN REVERSE!! We just pulled the codes and got "P320 Module Ignition Distributor Engine Speed Input Circuit"...
2000 Explorer EB 4.0l
Any suggestions??
Thanks
Any suggestions??
Thanks
Engine stall, failure to idle at all, suggests locked-up torque converter clutch. Why T.H. it would release in Reverse eludes me. At any rate, DISCONNECTING the electrical feed to the Torque Converter Clutch Solenoid would confirm; engine would not stall if clutch is locked-up.
This may be accomplished by removing the appropriate fuse, maybe.....I do not have my schematics here with me sorry.
Anyone else?
Anyone else?
These solenoids frequently fail. Mine did, 2004 Explorer, 100K miles. The replacement solenoid "module" I ordered on E-bay, $85.00, replaced it myself.
If indeed your solenoid is the cause of the problem, replacing the entire transmission is ridiculous, unless it has additional other "issues".
Hey,
When you say replaced it yourself, you opened the tranny? My mechanic says he is not a Transmission Guy and seems worried to open it up. I feel no way about it as I see it as pooched either way..
So do I need to remove the transmission to do this? Should I have it towed elsewhere? (dont really wanna pay to tow it again)
If I open it up will it all fall apart??? Or will I see the Module as I will have the switch in my hand??
Sorry for the lame questions..
Any pictures or diagrams online?
thanks in advance
thanks in advance
Hey,
thanks in advance
thanks in advance
If you are mechanically inclined, and have done ANY work involving parts held together with screws, and sealed with gaskets (the oil pan gasket is RE-USABLE, by the way, if not damaged), you may be able to "pull it off" yourself. Replace the filter with a new one, discard the drained-out old fluiud, and put in new transmission fluid of the correct type. There are many threads in the forum revealing further details........let us know how you make out!
302excursion
08-11-2018 09:32 PM
5. Slow
01-06-2010 12:14 PM
