to airdog or not to airdog that is the question
Rather a course screen, but it stops anything bigger than the pump can chew up and send along to get caught in the fuel filter.
Been running this setup trouble free for about three years now.
This is the gallery that I made when I did the job.
Pictures always do a better job than a long explanation.
1999 Ford F550+ 4x4 - Fuel Pump In the Tank
Air Dog
I installed the air dog and really like it. Diesel fuel contains entrained air, it is introduced as you drive, as you fill your tank, the ford fuel system has a number of areas that introduce air while the truck is running such as the fuel line connections pre-factory fuel pump, they are good at not leaking fuel under pressure but not good at not leaking air into the system under vacuum. The fuel pick up in the tank introduces air as well. The air dog removes this air. After installing I noticed immediately how much quieter the engine ran as well as smoother running on the road. As for mileage increase, if I keep my foot out of it I gained @ 1 mpg. To me it is a worth while mod.
Dan
Dan
I will concede there may be air introduced from sloshing fuel and maybe from the QD fittings on suction-side of pump - but the factory filter is very effective at removing it. The fuel flows in the bottom of the filter housing and MOST of that fuel is discharged out the top of the housing via the FPR/return. The fuel that is being consumed by the engine must pass thru (2) layers of the factory filter and DOWN thru the filter media to exit the bottom of the housing on the opposite side of the inlet. These redundant measures designed specifically to remove air work very well. Even if some air gets past all of this - we probably have the most tolerant injection system anywhere for entrained air.
Dan, I am confident you noticed a quieter engine after Air Dog had been in there awhile. This is an indication you had some air trapped in the end of the fuel rails. I think this happens all the time because people don't know to cycle the key a few times after changing filter or draining the bowl. I bet 50% or more of the PSD owners I've met have NEVER done this - the truck always starts right up, so they didn't even know it was bad practice!!
The only way to increase MPG's in these trucks is to 'keep your foot out of it'.
