dually adapters - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
dually adapters
Old 03-17-2011, 10:05 PM
OrFordGuy OrFordGuy is offline
OrFordGuy is starting off with a positive reputation.
dually adapters
looking for 95-99 dodge dually front adapters....and related hardware...some newer dodges might work..iknow thw 4X4 ones will work but the 4X2 might....need to be 6 1/2-7" from mounting flange to wheel flange...and must be 8 on 61/2 bolt pattern...will pay shipping and finders fee if someone can locate them..
Old 03-24-2011, 11:57 PM
turns out the 4X2 dodge fronts won't work but the 96-03 GM dually 4X4 fronts will also work...
Old 04-06-2011, 07:38 PM
gr8whitebronco gr8whitebronco is offline
gr8whitebronco is starting off with a positive reputation.
Is there a reason why ford 8 on 6.5 dually adapters would not work?? I have a set for $50 plus shipping if they will work
Old 04-08-2011, 01:08 AM
there is 2 possible reasons why... if there shorter than 5" then there 2 short... if there from a 4x2 then they won't fit a 4X4... if you have aftermarket adapters that fit my needs id be really intrested...and a quate on shipping to 97386...
Old 04-19-2011, 01:27 AM
they chevys fit a buddy gave mr one to test... and there only 4 1/2" wide.. and spacers may be needed for the raer axle... will update if i find more adapters..
Old 04-19-2011, 04:15 PM
I measured the for ones I have that are Ford 4X4 and they are 5-1/2 inches apart
Old 04-19-2011, 10:31 PM
the 5 1/2" is from rotor face to wheel mounting surface????
and what year ford did they come off of????
do they fit over the selector hub or does it fit in the adapter??
Old 04-20-2011, 05:00 PM
Yes from rotor face to mounting surface, I believe 1988 and 4wd hub goes into adapter.
Give me a e-mail address and I'll send pics. Scott.
EGR Tube & Manifold Adapter: 1984(ish) 4.9L 300 F-150 4x4 akf150-300 Ford Inline Six, 200, 250, 4.9L / 300 5 05-18-2014 06:03 PM
hopping/shaking dually -issue resolved. FORDF250HDXLT Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 05-16-2011 08:07 PM
Ford or Dodge - I think I might have made up my mind on which one! Killrail 1994.5 - 1997 7.3L Power Stroke Diesel 40 09-01-2009 03:22 PM
'70 F250, Dually axles/brakes... SillyValleyF250 1967 - 1972 F-100 & Larger F-Series Trucks 12 07-22-2008 02:06 AM
Ford pulling truck's!! supercab4x4dually General Automotive Discussion 31 08-25-2004 08:50 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
04, 07, 08, 1994, 2002, adapers, adapters, dually, f150, f250, f350, ford, tuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
