I love my new radiator an electric fan - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 08-01-2013, 06:18 PM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
I have a 30 amp fuse on the low setting 12V to the fan and I have an 80 amp fusible link to the high setting 12V.
  #122
Old 08-01-2013, 08:45 PM
abyars111's Avatar
abyars111 abyars111 is offline
abyars111 is starting off with a positive reputation.
my kit from Hollister Co has a 50 amp, that's what they use in their trucks
  #123
Old 08-01-2013, 08:48 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Quote:
What link to the product?
  #124
Old 08-01-2013, 08:55 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
Hollister Road Electric Fan Components
  #125
Old 08-01-2013, 09:00 PM
Which kit would be better? I plan to put AC back in my Bronco one day.
  #126
Old 08-01-2013, 09:44 PM
abyars111's Avatar
as we speak I'm installing the 185 200 w a/c kit
I'm looking for a key on pwr source right now. I had to come consult my shop manual.
  #127
Old 08-02-2013, 12:43 PM
abyars111's Avatar
I finished the fan install last night. We are getting ready to take the Crew on a camping trip and have zero time to go to the bone yard so, don't laugh, I bought a new fan. At the advice of David Chapman of the Hollister Company I ordered the T-Bird fan, TYC part no. 620950. I bought it from Amazon, $77 and free shipping. I used the Hollister kit, 180 switch, 200 switch and A/C relay. It is a very nice kit if you don't want to piece it together yourself. David is very helpful as well.
The fan seems to work really well. I'll be testing it soon towing our camper.
  #128
Old 06-28-2014, 12:45 PM
6ohman2004's Avatar
6ohman2004 6ohman2004 is offline
6ohman2004 is starting off with a positive reputation.
I know this is a pretty old thread, but it helped me a lot. And now I'm looking to do this mod.
I plan to go to the jy and pick up a fan next check, build my own brackets and I plan to use the wiring kit from Hollister co.
I do have a few questions though.
What are the best cars to get the fan from, the Mark 8 and t bird. Any others?
What part besides the fan might I need from the car? Connectors?
where does the temp sensor kit screw into the manifold?
how does it read the temps?
would it work an Edelbrock 4 barrel manifold?
  #129
Old 06-28-2014, 12:53 PM
HIO Silver's Avatar
What's the best car to get the fan from, the Mark 8? Any others?
  • Lincoln Mark VIII, T-Bird, or Taurus
  • The fan and its plug. Get as much of the wiring to the plug as possible.
  • Temp sensor is mounted in the same place as the OEM sender. Or keep the OEM sender and use a T-fitting... Or mount it in the thermostat housing. Ya didn't say what engine ya got..... but FE housings have a boss that usually has a pipe plug.
  • Temp senders operate via resistance.
  • Yes.
Custom brackets:
  #130
Old 06-28-2014, 01:03 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
@ HIO nice job on the brackets and install
What engine bay and engine is this ? seems to be no clearance issues ..
  #131
Old 06-28-2014, 01:29 PM
6ohman2004's Avatar
Thank you for the detailed help and pictures!
I'm sorry I forgot to mention I have a 79 f150 with a 351m built to the 400. soon to have the Edelbrock 4 barrel setup. I also installed a dual battery system with a 180 amp alternator so I should be set there.
I'd really like to keep the stock gauge working I now have a pretty good idea of the actual temps on the gauge as I've checked with my ir heat gun. The t is for me then ha ha.
So from what I've gathered it is the same fan for both the v8 and v6 then?
Any other tips I should know before attempting this install?
  #132
Old 06-28-2014, 02:37 PM
HIO Silver's Avatar
Thanks. The pics are of my '70 with a 360FE... removal of the mechanical fan, spacer, and should frees up lotsa room.
I'm swapping to the Edebrock E-Street EFI and the comes with software to control a two speed electric fan.... adjustable too via the tablet interface.
Sho' thing.
The fan you're looking for has a three-wire plug. You do have the option of getting a dual fan set-up from the Taurus. The same principles apply.
Please read thru the following threads/pages for detail:
Electric Fan/Cooling Upgrades
Ford Muscle: Lincoln Mark VIII Retrofit
Fordification Thread: Lincoln Mark VIII/T-bird Two-Speed Fan Installation
Pro-Touring.com Thread: Mark VIII fan & SPAL Controller
The Fan Man - Electric Fans & Controllers
Nasty Z28 Thread: Budget Dual Electric Fan Controller Set Up
Centech Fan Controllers
  #133
Old 06-28-2014, 04:21 PM
6ohman2004's Avatar
I just emailed David Chapman at Hollister and he was super helpful! Ha you don't get to many people mailing back on a Saturday.
But I've got my shopping list and I'm excited to get rolling on this soon.
Also rock auto has these fans new for 70$ just in case you went a brand new one instead of 10 years old. And I feel that's still a good deal.
Thanks for all the help and reviving an old thread!
  #134
Old 06-28-2014, 11:24 PM
abyars111's Avatar
David at Hollister really helped me with my set up. Very good customer service in my opinion.
David recommended the TYC brand to me as a supplier for the fan. I ordered TYC part no. 620950. It has a lifetime warranty.
David now has the BMW dual temp switch and the necessary metric to NPT adapter to mount into our manifolds or thermostat housing. I plan to change my setup in the future to this. I currently have a pipe with a bung in it for the hi speed switch on my upper radiator hose. I got this from David as well.
  #135
abyars111's Avatar
Vintage Picture Thread. (WARNING: 56K ~ Picture Loadin' Death!) 76f350spercamprspeal 1973 - 1979 F-100 & Larger F-Series Trucks 97 04-03-2016 11:16 PM
48' F1 PROGRESS BUILD !! cashy52 1948 - 1956 F1, F100 & Larger F-Series Trucks 45 09-07-2015 10:35 AM
New Member- My '51 Project So Far 2" Chop (Pics) Bgrassguitar 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 08-22-2013 04:32 PM
The lost Before an After pics of my 72 highboy! akforceten 1967 - 1972 F-100 & Larger F-Series Trucks 7 07-08-2011 10:06 AM
A little OT, just some recent pics of the trucks plgebbia 1994.5 - 1997 7.3L Power Stroke Diesel 38 05-02-2011 08:39 PM
Tags
60, amp, bronco, contour, conversion, draw, electric, f150, f350, fan, ford, radiator, tbird, truck, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
