I love my new radiator an electric fan - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 06-02-2011, 09:39 AM
akforceten's Avatar
akforceten akforceten is offline
akforceten is starting off with a positive reputation.
The low speed would be plenty an put a 180 stat in or lower . I run mine a low all the time though a toggle switch wired to a Ignition on power source. I never have had to use the high setting the T-bird /mark 8 fan does move a lot of air . When it get in the 90's I run at 190 all day long! I have never had a overheating problem since I have done this conversion . Just make sure you use 2 relays.
  #47
Old 06-02-2011, 09:47 AM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
I'm sure it'd be fine to run it only on high and leave low disconnected. If I were going to do it that way I'd at least put in a cheap thermostatic control so that it didn't even kick on until a certain temp though.
  #48
Old 06-02-2011, 10:00 AM
psquare7575's Avatar
psquare7575 psquare7575 is offline
psquare7575 is starting off with a positive reputation.
I've wanted to do this for my F100 for quite some time, but I am concerned how it'd be to tow with.
  #49
Old 07-26-2011, 12:28 PM
McFallTM McFallTM is offline
McFallTM is starting off with a positive reputation.
Rad and electric fan
FTE users! Thank you so much for all the great info on this mod. I'm a new user and new owner of 73 F100 390 Automatic w/ factory AC. I cannot get my 73 to stay cool - Granted it's 100+ in AZ but I cannot get it to run normal temps, tipping the gauge to extreme. Using OEM fan clutch, installed fan shroud, new stat, new radiator copper/brass big'un 24 1/4" and now contemplating electric fan. This thread has helped greatly and I sure do appreciate all the words of wisdoms. With such a larger core, any idea of elect fan, with some slight fab work that would be best?
  #50
Old 07-26-2011, 01:23 PM
scarey1 scarey1 is offline
scarey1 is gaining momentum as a positive member of FTE.
fans
Hi,Welcome.I have never had great luck with electric fans keeping big engines cool. I run a 10 to 1 460 in my 79 bronco. I live near sacramento,It sees 90-100 degree heat Never gets hot even with the a/c on. What thermostate are you running? Is the HD fan clutch working?(can you hear it come on?) Have you used a thermometer in the radiator to seee what temp its running? Scott
  #51
Old 07-26-2011, 06:13 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Quote:
Ever hear of the Lincoln Mark VIII/ TBird fan?
Josh
  #52
Old 07-26-2011, 06:15 PM
Quote:
Scott - Thanks so much for the reply. I was concerned about that, plus I'm planning to use my 73 to tow the boat rather than my daily truck, ashamed to say what that is, LOL, so I want to be abosultely sure. I'm using a 195 degree superstat. The HD Fan clutch is working great. I haven't tested the temp yet, I plan on doing that tonight. If there's any other gotchas you might be able to share that would be great. I'll post an update later tonight along with my pics. Thanks again!!!
  #53
Old 07-26-2011, 06:21 PM
180
Hi,I would use a 180 degree. It should read 1/3 to at the most 1/2 of the factory gauge (providing it is somewhat accurate) hope it helps,Scott
  #54
Old 07-26-2011, 07:45 PM
Bullitt390's Avatar
The factory gauge does a better job of telling the outside temp than it does engine temps.
You want the 195 t-stat with a high quality radiator.
The Mark VIII electric fan is considered the BEST fan for the job and shouldn't be confused with aftermarket rinkey dink electric fans. No matter if that garbage cost $50 or $500 they do not hold a candle to it.
Josh
  #55
Old 07-28-2011, 09:51 AM
akforceten's Avatar
With the summer temps climbing I would like to report the the Mark vIII / T-bird electric fan on the low setting has performed flawlessly an the truck stays cool!
The electric fan upgrade is one of best! I will be doing this to my bronco .
  #56
Old 07-28-2011, 12:37 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
I live near Sacramento too and am running a mild 460 in my f250 4x4. I am running a desert cool radiator and a mark VIII fan controlled by a delta curent control. My motor temp stays pegged once she's warm right at 190.
  #57
Towing anything?
  #58
Old 07-29-2011, 09:14 AM
akforceten's Avatar
Yes I tow with the truck an haul heavy load's ,plus in the winter time I plow lot's of snow.
  #59
Old 08-06-2011, 02:50 PM
After all my tinkering, I've decided to try the Mark VIII so I'm off to the yard to see what I can find. I did get the temp down with a new 180 thermostat which is nice, but running the A/C and idling it's a little hotter than I like. Thanks again for all the insight!
  #60
Old 08-06-2011, 09:14 PM
CaptainIPSC CaptainIPSC is offline
CaptainIPSC is starting off with a positive reputation.
I've had a few issues with engine temps varying more than I'd like but after reading this article I only use balanced thermostats and they do make a difference.
Performance Unlimited 4-Wheel & Off Road Center - Hartford, Wisconsin - USA
3 Projects out of the way (DONE) tasboj 1967 - 1972 F-100 & Larger F-Series Trucks 19 01-21-2013 07:28 PM
89' f150 pics. proof that bricknoses can look good Nally427 1987 - 1996 F150 & Larger F-Series Trucks 20 09-08-2012 10:04 AM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 08:46 PM
Finally putting a 3g alternator in my 72 highboy akforceten 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-27-2011 09:41 PM
Finally putting a 3g alternator in my highboy akforceten 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-27-2011 08:33 PM
Tags
60, amp, bronco, contour, conversion, draw, electric, f150, f350, fan, ford, radiator, tbird, truck, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
