5.8 Exhaust Manifolds - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-23-2014, 12:28 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Originally Posted by PRIMERED79 SHORT BED View Post
Did you reuse the old bolts?
Mine are pretty corroded, so getting new would probably be the best.
new bolts. Highly suggest you do the same.
  #32
Old 02-23-2014, 12:42 AM
PRIMERED79 SHORT BED PRIMERED79 SHORT BED is offline
PRIMERED79 SHORT BED is starting off with a positive reputation.
I found a bolt kit on O'reilly's site, I'll get that when it come time.
  #33
Old 02-23-2014, 08:16 PM
TX92F150's Avatar
TX92F150 TX92F150 is offline
TX92F150 is starting off with a positive reputation.
Back when I replaced my manifold, I replaced all the bolts with a kit I picked up at the parts store. Everything went together well, and is still working for me. I'd always replace the bolts when R&R'ing a manifold; cheap insurance.
Cheers,
JD
Broken exhaust manifold bolt, 1994 5.8 L? Dean06919 1987 - 1996 F150 & Larger F-Series Trucks 7 11-21-2016 11:34 AM
1993 F150 Exhaust Manifolds - Gaskets? jeff9942 1987 - 1996 F150 & Larger F-Series Trucks 18 09-27-2016 07:51 PM
5.8 W Exhaust Manifolds no AIR in , EGR riser on RH grinditout Ford Truck Parts for Sale 0 03-01-2015 06:15 PM
Exhaust Questions: 92 F150 5.8 TX92F150 1987 - 1996 F150 & Larger F-Series Trucks 13 02-23-2014 09:03 PM
92 F150 302 exhaust manifold Avanti 1987 - 1996 F150 & Larger F-Series Trucks 3 12-20-2001 02:06 PM
Tags
1996, 58, bolts, broken, chinese, egr, exhaust, f250, ford, good, header, leak, mahifold, manifold, manifolds, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
