5.8 Exhaust Manifolds - Page 2 - Ford Truck Enthusiasts Forums
Old 03-26-2011, 02:56 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Have a auto shop with a machine shop resurface it.........$15.00 last time I had it done.
Your old OEM is better than a new Dorman.
Old 03-26-2011, 03:21 PM
mean green 91's Avatar
mean green 91 mean green 91 is offline
mean green 91 is starting off with a positive reputation.
$230 for pacesetter 50 state legal shorties. i dont know what your budget is but i have these and i love em. could do em now while your already having exhaust issues
Old 03-26-2011, 10:04 PM
TX92F150's Avatar
TX92F150 TX92F150 is offline
TX92F150 is starting off with a positive reputation.
Back together and running good now. I can't believe how quiet it is with the manifold leak fixed. It may be me, but I think it runs better too. After a test drive, I pulled codes and everything is clear. After having the battery out of it for 3 days, the computer is relearning the parameters, and hopefully, the codes will not return.
I agree that an OEM manifold is better than an aftermarket replacement, but I simply didn't have any other choice. I need the truck back in service to go to the airport Monday morning (I take the truck instead of my "good" car to sit in the parking garage). Resurfacing the original wasn't an option this time. In addition to being warped in the axis that mates to the cylinder head (fixable), it was also warped along the length (think banana), causing the holes not to line up; not even close. There's no fixing that. The Dorman DID fit like a dream, and looks like a decent piece. Time will tell if it holds up, but others here have had good luck with them in this application.
Same thing for the headers; no time. Also, I just don't like fooling with headers, and have no plans to modify the truck whatsoever, single exhaust and all. Plus, they always seem louder (through the firewall), which is exactly what I was trying to avoid. If I have more manifold issues in the future, these may be the way to go to avoid further warping hassles.
Thanks for all the great input!
JD
Old 03-27-2011, 02:14 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Glad to hear you got everything back together.
Old 06-02-2011, 03:02 AM
jumbofordman jumbofordman is offline
jumbofordman is starting off with a positive reputation.
Quote:
Get summit brand headers - they are Pacesetters (even has a pacesetter sticker in the box) Only run about $170. I'm not usually a Pacesetter fan, but they have pretty thick metal on them as well as thick flanges.
I'm running into a bit of a problem installing mine, though. I took off the driver's side no problem, but I've only taken out one bolt on the passenger side and it broke right at the head. Looks like I may have to take off that head in order to extract the remainder of the bolt, as there is no room to get any tools down there.
Old 06-02-2011, 10:22 PM
firewood truck firewood truck is offline
firewood truck is gaining momentum as a positive member of FTE.
Thanks for this thread, I'm prepping a 5.8 to go into my F250 and the right side exhaust mani has a crack between cylinder 2 and 3 plus my EGR tube flex joint was non-existent. I basically have no budget to work with so I wasn't sure what to do about the broken manifold. I've seen the Dorman replacements on fleabay but I was too sure about them, your review helped me to decide to give it a try.
Old 06-03-2011, 10:13 AM
rla2005's Avatar
PCI Inc. sells the EGR tube. Rock Auto carries them as well.
I have had the Dormans on my F350 for almost two years now with no issues.
Old 02-16-2014, 09:38 PM
TX92F150's Avatar
UPDATE
Just a quick update on my Dorman exhaust manifold. It's been a few years since I installed it, and it's still working great. No leaks or other issues. So, from my personal experience, I'd say that it's a decent piece that has served well so far. Just wanted to update this in case someone is in the same position as I was, and is wondering if the Dorman is a viable option. It is.
Cheers,
JD
Old 02-21-2014, 11:22 PM
PRIMERED79 SHORT BED PRIMERED79 SHORT BED is offline
PRIMERED79 SHORT BED is starting off with a positive reputation.
When you took the manifold off originally, how did you manage to remove the bolts without breaking any?
Did you use any heat, special tools?
Old 02-22-2014, 03:56 AM
zspeed130 zspeed130 is offline
zspeed130 is starting off with a positive reputation.
+1 on the above. I am trying to decide on doing mine in the garage or paying a shop. I am going to do pacesetter ceramic coated long tubes though.
Z
Old 02-22-2014, 07:16 AM
rla2005's Avatar
I soaked the manifold bolts with PB Blaster for a few days. I also ran the truck for a few minutes each day. I did the same thing just before I started the R&R. When I felt a bolt was not coming out easily I applied a little heat with a propane torch and more PB.
None of my bolts broke on me . Heat, PB and time are your friend. My truck was not a DD so I had the luxury of time too.
Old 02-22-2014, 09:46 AM
Did you reuse the old bolts?
Mine are pretty corroded, so getting new would probably be the best.
  #28
Old 02-22-2014, 06:39 PM
Island'r's Avatar
Island'r Island'r is offline
Island'r is gaining momentum as a positive member of FTE.
Chuck them and get new ones...
I have to pull my passenger side manifolds, as one of the bolt heads is snapped off, and that may be causing the leak.
I'm really not looking forward to it. Trying to find a small oxy setup before I even think of starting it, and also a time when I can have the truck down for a while...
I've found in the past that removing the bolts when the engine is warm, sometimes helps. PB blaster is definitely one of the most amazing things I've ever used...
  #29
Old 02-22-2014, 08:04 PM
I took mine for a long drive today after a good ole tune up.
Came home and was finally able to crack lose the EGR tube, it was seized pretty good.
I will do the same for the O2 sensor and the exhaust manifold bolts.
  #30
Old 02-22-2014, 08:32 PM
Old93junk's Avatar
NEVER re-use old ex-manifold bolts, you are lucky when they come out in one piece, let alone going back in to torque.
Get new non-plated grade-8 bolts.
Broken exhaust manifold bolt, 1994 5.8 L? Dean06919 1987 - 1996 F150 & Larger F-Series Trucks 7 11-21-2016 11:34 AM
1993 F150 Exhaust Manifolds - Gaskets? jeff9942 1987 - 1996 F150 & Larger F-Series Trucks 18 09-27-2016 07:51 PM
5.8 W Exhaust Manifolds no AIR in , EGR riser on RH grinditout Ford Truck Parts for Sale 0 03-01-2015 06:15 PM
Exhaust Questions: 92 F150 5.8 TX92F150 1987 - 1996 F150 & Larger F-Series Trucks 13 02-23-2014 09:03 PM
92 F150 302 exhaust manifold Avanti 1987 - 1996 F150 & Larger F-Series Trucks 3 12-20-2001 02:06 PM
Tags
1996, 58, bolts, broken, chinese, egr, exhaust, f250, ford, good, header, leak, mahifold, manifold, manifolds, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
