Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > EcoBoost (3.5L, 2.0L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
EcoBoost (3.5L, 2.0L) 3.5L Twin Turbo EcoBoost V6 and 2.0L I4 EcoBoost Engines
  #1 (permalink)
Old 03-17-2011, 05:55 PM
boomer08 boomer08 is offline
Garage is empty, add now
boomer08 is starting off with a positive reputation.
Questions on Ecoboost
I obviously have a 2011 F-150 with the Ecoboost. Looking in the manual it shows that is takes an oil filter with the number FL-500S. After digging through some more papers in the glovebox I come across a maintenance and specifications sheet that says it takes a FL-2055 filter. Does one filter better than the other. I wonder what the difference is.
Also I want to get a fumoto oil drain valve for the truck. They need to know if the 3.5L is a 12valve or 24 valve engine. Sorry I am not a mechanic.
__________________
Boomer08
2011 Ecoboost White Platinum 4x4 Screw
  #2 (permalink)
Old 03-17-2011, 06:12 PM
Scorpion67 Scorpion67 is offline
Scorpion67 is starting off with a positive reputation.
The engine has 24 valves, sorry I can't help on the oil filter thing though.
  #3 (permalink)
Old 03-17-2011, 06:14 PM
mrpositraction's Avatar
mrpositraction mrpositraction is offline
mrpositraction is gaining momentum as a positive member of FTE.
Copied from another forum:
To:All Ford and Lincoln Dealers
Subject:EFC00063DC New Part Number FL2055, 2011 F-150 3.5L Ecoboost Oil Filter
INTRODUCING THE FL2055
Motorcraft is pleased to announce the availability of the FL2055. This all new oil filter is the service filter for the 2011 model year F-150, 3.5L Ecoboost engine.
All 2011 F-150 trucks equipped with a 3.5L Ecoboost engine were produced with a small diameter (77mm/3 inch) oil filter. The service replacement oil filter, the FL2055, is a larger diameter (94mm/3.75inch) filter. The FL2055 has significantly higher filtration efficiency and capacity than most other oil filters and is designed for added engine protection and long life. For proper engine maintenance, a FL2055 oil filter or an equivalent filter meeting Ford material and design specifications must be used.
If a replacement oil filter is installed that does not meet Ford specifications, engine damage may occur which may not be eligible for warranty coverage. The oil capacity for the 3.5L V6 Ecoboost engine with the FL2055 oil filter is 6.2 quarts (5.9L).
__________________
2011 F150 SCrew FX4 Ecoboost
  #4 (permalink)
Thank you. I appreciate it.
__________________
Boomer08
  #5 (permalink)
Old 03-17-2011, 06:48 PM
tseekins's Avatar
tseekins tseekins is online now
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Great find! The oil change interval is 10K miles so it's no surprise that the filter size needed to be increased.
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #6 (permalink)
Old 03-17-2011, 07:00 PM
NASSTY's Avatar
NASSTY NASSTY is online now
NASSTY has a very good reputation on FTE.NASSTY has a very good reputation on FTE.NASSTY has a very good reputation on FTE.
Quote:
Does it use 5W-30? Do they recommend full synthetic? I would think so with 10k mile intervals.
__________________
2011 FX4
92 Bronco
  #7 (permalink)
Old 03-17-2011, 07:46 PM
tseekins's Avatar
2011 Ford F-150
Quote:
According to the Ford rep that accompanied my ecoboost drive, the 3.5L requires 5w-30 MC semi syn oil. I think full syn would be a good idea but th e MC oil seems to be able to handle the job.
__________________
Tim
2010 Ford Focus
FTE Guidelines
  #8 (permalink)
Old 03-17-2011, 08:41 PM
gasbrnr gasbrnr is offline
gasbrnr is starting off with a positive reputation.
Fumoto #F-107. I like the one with the nipple.
  #9 (permalink)
Old 03-18-2011, 12:04 PM
juneau76's Avatar
juneau76 juneau76 is offline
2010 Ford F-150
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Quote:
I'm a big fan of nipples (on certain things), too.
__________________
Brad
2010 F-150 XLT Supercrew 4x4 5.4L
2013 Explorer Limited (The wife's family truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #10 (permalink)
Old 03-19-2011, 08:37 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
Moved to correct forum.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #11 (permalink)
Old 03-20-2011, 07:53 AM
NASSTY's Avatar
If I run Motorcraft semi-synthetic I'll probably stick with my usual 3k-5k mile oil changes. I'm not real comfortable with 10k mile changes without full synthetic oil. Maybe my 3k-5k mile routine will be overkill but I'll sleep better at night.
__________________
2011 FX4
92 Bronco
  #12 (permalink)
Old 03-29-2011, 10:50 PM
jimmyb08SD's Avatar
jimmyb08SD jimmyb08SD is offline
2013 Ford Explorer
jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.
I hear ya, I cant seem to wrap my mind around 10K intervals either!
__________________
2013 Explorer XLT Kodiac Brown 3.5 V6
2008 Mercury Mariner Premier
Jim, Fl. Chapter Leader"Army Vet. and American for Life"
View my Gallery here- or http://www.ford-trucks.com/forums/me...lorer+xlt.html
Join the
Florida Chapter Here
Tags
150, 2011, 35, 35l, capacity, drain, ecoboost, f150, filter, fl2055, ford, lightning, motorcraft, oil, reviews
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
