I've had it with these Body Mounts!! - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 03-17-2011, 06:25 PM
LivingLarge's Avatar
LivingLarge LivingLarge is offline
LivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputation
Is there anything else I can do?
That body mount noise is finally getting to me. I feel like driving the EX into a palm tree sometimes, but then remember that I would probably just drive through it with little damage!
Things i have done:
1) I replaced at Ford at 100,000 miles, No Lube (lasted about 30k)
2) I loosened up the mount and lubed it (lasted about 1 month)
3) I tightened the hell out of it instead of the normal 82-87 lbs (lasted about 2 weeks)
4) Had it removed, took shaft to the grinder took off 1/8 in on each side. (lasted about 1 month)
This is the mount on Drivers side. All Others are tight, no noises and no sign of body movement.
My question is, has anyone tried something else that has helped?
Maybe a different body mount? Maybe a different manufacturer?
Your ideas are greatly appreciated.
Old 03-17-2011, 08:07 PM
Gfisher Gfisher is offline
Gfisher is starting off with a positive reputation.
I hate that squeak!No help though I'll be checkin back.
Old 03-17-2011, 10:19 PM
UrbanXX's Avatar
UrbanXX UrbanXX is offline
UrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputation
Man I know where you are comming from.
How to tell if you need body mounts.
Try to replace a front turn signal bulb. If you can't see the bottom phillips head screws for tha assebbly then the body has sunk or the body mounts have colasped. The bottom screws will be slightly below the top edge of the bumper.
I'm thinking about replaceing mine, but it looks like a lot of work.
Old 03-17-2011, 10:44 PM
Unfortunately Ford does not have a complete kit, so each one is about $90.00 (needing 12 i believe) and labor is about a full day to lift body off frame, replace mounts and put interior back together . That is a ton of money! I would do it but i think if it did not give me at least two years i would just loose it!
My teenage daughter has suggested new sound system, rub some dirt in it, suck it up, etc.
Would hate to go that route, will see.
Old 03-17-2011, 10:51 PM
UrbanXX's Avatar
We had a thread somewhere on this before and seems like somebody found them aftermarket for about 20.00 a piece. I think the first 2 sets on the front are the ones that go first.
Old 03-17-2011, 11:46 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is online now
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
i've heard is this issue but not had it in any of my 3 excursions...fingers corssed!
Old 03-18-2011, 12:07 AM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
I'm sure she would love for you to go this route.
Mine gets off road duty so I learn to ignore or just crank the tunes higher when I start hearing all the kreeking noises from underneath. Now that I have finished my new stereo I have more reason to enjoy the tunes cranked.
Old 03-18-2011, 04:39 AM
loleuiha's Avatar
loleuiha loleuiha is offline
loleuiha is starting off with a positive reputation.
I have been wondering what that squeaking noise is when I drive. It sounds like a squeak rattle combination kind like the sound of a piece of paper flapping real fast at a high pitch. Is that the sound from a worn body mount?
Loleuiha
Old 03-18-2011, 06:01 AM
3fingervic 3fingervic is offline
3fingervic is starting off with a positive reputation.
Other than the annoying sound, is there a real problem? BTW, I get a strange sound when I stop, is that the springs flexing?
Old 03-18-2011, 08:04 AM
Quote:
Maybe that Alaskan Mud is helping you out. Your lucky you don't have to deal with. It sucks!
Truck still looks like a $40,000 Ride
Truck Runs like a $40,000 Ride
When creaking noise starts
Truck feels like your driving a $400 clunker.
Old 03-18-2011, 08:09 AM
Quote:
I would probably just replace the 2 under the front floor board area, if i need to go original. I just would hate to have them all done.
Old 03-18-2011, 08:13 AM
Quote:
Sounds like you have the same problem, noise seems like it comes from rear of front springs, but its the body mount. Its not a safety problem.
Old 03-18-2011, 08:18 AM
Quote:
Loleuiha
Its more like a creaking sound, usually when you stop or sometimes if you takeoff fast, they progressively get worse to the point they can make noises when turning into driveways or hitting a large bump etc.
Old 03-18-2011, 09:06 AM
CrzHelm's Avatar
CrzHelm CrzHelm is offline
CrzHelm is gaining momentum as a positive member of FTE.CrzHelm is gaining momentum as a positive member of FTE.
Had a squeak on mine everytime i stopped or left. It turned out to be the leaf spring shackle. I rounded the bolt a few turns with silicone spray and problem gone.
Old 03-18-2011, 09:36 AM
CanadianSmokie's Avatar
CanadianSmokie CanadianSmokie is offline
CanadianSmokie is gaining momentum as a positive member of FTE.CanadianSmokie is gaining momentum as a positive member of FTE.
I keep hearing the sound described as a sqeak but I get this deep, clunk sound... like something in the suspension loading up and then releasing. I've had the front end checked over numerous times to try and identify it but everything is tight. Could think occasional clunking sound be the mounts? Does anyone else have this deep rubbing/clunking?
OEM Skid Plates Installation bives 1999 to 2016 Super Duty 36 07-06-2015 09:21 PM
4" Exhaust on 7.3L PSD Driving me crazy!! Please help! AdVANtureMan 1968-2013 Full Size Vans 6 09-22-2014 09:19 PM
Nice Grinding noise coming from the driver side...help? zacm7 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 05-09-2014 02:08 PM
Desperate for Body Mounts AggieOutlaw Excursion - King of SUVs 8 07-24-2013 06:32 PM
squeak pop under drivers feet bigbugman Excursion - King of SUVs 11 04-21-2009 09:23 PM
Tags
1996, 2002, bodies, body, bolts, excursion, explorer, f250, fix, ford, mount, mounts, noisey, rear, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
