ATTENTION ECOBOOST OWNERS - Page 3 - Ford Truck Enthusiasts Forums
EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
  #31
Old 02-27-2013, 05:37 PM
Charlie Bravo Charlie Bravo is offline
Charlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to all
Since it is a direct injection engine some of the black may be from the valve stems. My truck does it, I ain't worried about it, runs good for now. When I start my engine I let it idle for a minute and go. I let it idle for a minute and shut it off. According to posters on this site the coolant still flows to the turbos after shut down. And I would think that oil flows to them also. They sit lower than some parts of the engine. CB
  #32
Old 03-12-2013, 04:39 PM
Bill Reaves Bill Reaves is offline
Bill Reaves is starting off with a positive reputation.
150 ecoboost smoking issue
Quote:
Originally Posted by BK Broiler 74 View Post
Mine does this too exactly. I have a 2012 f-150 ecoboost with 5000 miles. Dealership mentioned it was a standard operation of this engine.
My truck is in the shop now for this very reason the dealer has ran codes and all sorts of test only to tell me that Ford has a TSB on it that states this is normal for a turbo vehicle they said it has to do with a cold start up and turbo warming time because the gas is being sprayed at such a high rate of pressue and delivery time that is doesn't have time to burn it off makes sense but sure makes the pipes dirty as hell. I guess this is something we owners are going to have to live with. in another topic is anyone having problems with a bumping or snap at stopping and starting like its coming off the rear end, they put new clutches in mine and changed the gear oil but its still doing the same thing?
  #33
Old 03-20-2013, 08:17 PM
blkandchrome blkandchrome is offline
blkandchrome is starting off with a positive reputation.
Sounds like your describing a common issue with trucks period. I just had my 2011 f150 fixing for this problem. It's the driveshaft slip yoke where it's mated to transmission needs lube so it can slide back and forth when stopping and taking off. I've had this problem with every truck i've owned, Toyota, GM, Ford. Im super sensitive to this now so I amagine most people dont even thinks it's erritating. I think there's a TSB for it.
1989 E350 with 5.7l Idles rough and rich when cold timmer117 1987 - 1996 F150 & Larger F-Series Trucks 9 11-24-2015 08:06 AM
3.5 Ecoboost Slow to Start? bridomine99 2009 - 2014 F150 5 10-15-2014 05:58 PM
7.5L rough idle when cold Infinite Monkeys 1987 - 1996 F150 & Larger F-Series Trucks 15 07-02-2014 11:48 AM
2013 F150 Ecoboost 2K miles Engine Knock!!!! nascar991 2009 - 2014 F150 51 02-27-2014 08:35 PM
2003 f-350 running rich !!!!! grimey4life Modular V10 (6.8l) 6 03-03-2011 03:01 PM
Tags
12secrd, 150, 2011, 4x4, 66, bed, black, clutch, ecoboost, exhaust, f150, ford, forums, lariat, manual, owners, soot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
