EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
ATTENTION ECOBOOST OWNERS
Old 03-24-2011, 09:56 AM
12secrd's Avatar
12secrd
12secrd is offline
Noticed the fuel mixture was worst upon today's start up but it cleaned itself up after 35 secs.
Ford needs a ECU flash update to clean this poor a/f up.
Come on Ford I know your reading...
Old 04-09-2011, 11:23 PM
traveller1002000's Avatar
traveller1002000
traveller1002000 is offline
I think I read that the Ecoboost engine has a special shutdown mode that lets the turbos cool down gradually, keeps pumping oil to them. There has been after market kits for older trucks to do the same thing.
Bill
Old 04-10-2011, 09:20 AM
spdmpo's Avatar
spdmpo
spdmpo is offline
I think maybe you aren't understanding that it appears they have done this on purpose. Throwing more fuel at it gets the turbos spinning and warmed up at first start. That way there is some heat in them so when an abusive driver turns the corner and mashes the gas they aren't completely cold.
Or hell, maybe im not understanding it correctly, but I can see no other logical explanation.
Old 04-10-2011, 05:51 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
The ecoboost i drove shut off after i drove it. No delay there.
Old 04-10-2011, 08:28 PM
spdmpo's Avatar
spdmpo
spdmpo is offline
Bill
Ummm, no, you either didn't read that, or what you read is wrong.
Old 04-11-2011, 07:36 PM
Rancheroracer's Avatar
Rancheroracer
Rancheroracer is offline
The Ford tech guy told me that's why they're watercooled & plumbed the way they are, they continue to cool after shutoff by thermosyphon. No oil flow after engine is shut off.
Old 04-12-2011, 11:10 AM
3bands's Avatar
3bands
3bands is offline
I don't know about startup, but my tailpipe is full of soot. Maybe it is like a Diesel.
Old 04-27-2011, 10:43 PM
robspowerstroke's Avatar
robspowerstroke
robspowerstroke is offline
I would like to add that my 2011 eco boost is making alot of black smoke when first started after sitting all night.. It cleans up in about 10 seconds.. It only has 650km on it..
Old 05-23-2011, 05:13 PM
Chesnut's Avatar
Chesnut
Chesnut is offline
Cool 3.5 ecoboost blows black smoke on cold startup
I have a 2011 F150 with the 3.5 ecoboost. I have noticed when I start it in the morning (cold start) I get some black smoke that lasts about 10-15 seconds, after that everything appears to be normal. I have taken it back to the dealership and explained the situation to them and they are totally unaware of what causes the smoke and have nothing in their service information stating if this is a normal process or not. Does anyone know for sure? Dealership seems to be clueless.
Old 05-23-2011, 10:35 PM
jimmyb08SD's Avatar
jimmyb08SD
jimmyb08SD is offline
Mine has no smoke, and very little soot or dirt in the tail pipe. Must be a cold weather/start deal.
Old 06-15-2011, 04:06 PM
donovan's Avatar
donovan
donovan is offline
Turbo's
All turbos used for pulling heavy object should be allowed to cool down by idle the engine a few minutes. We have to do this on our diesels. The barrings and the actuators need a little time to cool down. This will save you a boat load of money down the road.
Cold startups do burn more fuel to allow the engine/turbo to heat up.
Old 06-18-2011, 10:49 AM
egbertnr's Avatar
egbertnr
egbertnr is offline
Typical DI stuff here, my mazdaspeed was the same way, tailpipe were sooted up.
  #28
Old 06-19-2011, 12:34 AM
Jus2shy's Avatar
Jus2shy
Jus2shy is offline
I also read a recent article where Continental worked on a new DI setup that cures the cold-start soot problem using solenoid technology. So apparently, the OEM's are aware of this issue and it seems the heart of the issue is the solenoid actuated injectors and how close to the minimal amount of fuel they can get when lighting off a cold engine. It seems like other than Continental's solution, everyone else is looking at Piezo style injectors like in the new Diesel motors to get the fuel metering accuracy for cold starts.
  #29
Old 02-26-2013, 12:20 PM
BK Broiler 74's Avatar
BK Broiler 74
BK Broiler 74 is offline
Originally Posted by 12secrd
My F-150 ecoboost runs super rich when first started when cold. So rich that it will puff the black/unburnt fuel from the exhaust. This will happen when just idling or first accelerating off when the engine is completely cold.
Once the engine is warm the exhaust looks fairly clean
Anyone else noticing this?
PS I am aware that all engines run richer when cold until warmed up. But I just want to see if all ecoboost engines are doing this.
Mine does this too exactly. I have a 2012 f-150 ecoboost with 5000 miles. Dealership mentioned it was a standard operation of this engine.
  #30
Old 02-27-2013, 08:22 AM
03redstx's Avatar
03redstx
03redstx is offline
i noticed this right off the bat with my ecoboost, 6000 miles on it now..nowhere near as bad as my Grand National though, tailpipes are black inside
Quick Reply: ATTENTION ECOBOOST OWNERS
