Exhaust question
Exhaust question
Helpin a friend install a 4'' turbo back on his 96. He broke the bolt on the T clamp for the downpipe that attatches to the turbo, anyone know where to get that clamp?
He's also missing a few of the rubber mounts for the exhaust hangers and the instructions say to re use those, can't seem to find those anywhere either.
Thanks for the help.
This thread might help some
https://www.ford-trucks.com/forums/1...ust-clamp.html
Directs to this, may want to check dimensions though, as I'm not sure if it will work for our dp/turbo...
FORD CHEVY DODGE JEEP 3" V-BAND CLAMP TURBO DOWNPIPE - eBay (item 320636868895 end time Mar-30-11 18:52:25 PDT)
Thats its a good question, because the "normal" DP, O.D. is 3" IIRC. maybe someone else will chime in later.
Those pics are from a friend of mine (strokersace). The motor in his truck has a complete SD conversion- front cover/accessories, turbo, etc. He decided to nut up and try to make a 4" SD down pipe fit since he had it apart anyway, and well he's just the kind of guy who can't leave well enough alone
