Need Wiring Diagram For PCM - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-17-2011, 09:02 AM
fred.mason fred.mason is offline
fred.mason is starting off with a positive reputation.
Hey to all,
I have a 2005 F250 with a 5.4L 3V engine. I have been getting a CPS fault code. I have replaced both sensors and checked the alternator. I found a test procedure which had me disconnect the wires from the PCM and the sensors and check for voltage with the key on. It states that I should have less than 1volt on the + of the sensor harness at this point. I actually have almost 4 volts which indicates a short in the wiring harness. I need to trace the wiring through the harness and would like to know if any other devices share the suspect wire. I have been trying to find a copy of the wiring diagram but not having any luck. Would anyone happen to have a copy to share or know where I may find one?
Thanks
Engine & Tranny swap 1999 to 1997 bcarterjr New Member Introductions 3 07-02-2015 03:23 PM
99 F-150 Code P0443 Iceman5192 1997 - 2003 F150 2 08-15-2013 10:54 PM
Possible P0401 fix after EGR delete phatmarcus 6.0L Power Stroke Diesel 29 03-26-2011 02:07 PM
E4OD wiring diagram rcraig Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 02-20-2007 12:33 AM
Starter Wire Diagram (Schematic) 70 F100 Derwydi 1967 - 1972 F-100 & Larger F-Series Trucks 2 01-05-2001 09:39 AM
Tags
2002, 2004, 2008, 64, 73, 96, diagram, diesel, digram, eng, f250, f350, ford, pcm, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
