dana 44 vs dana 60 spindle
Old 03-17-2011, 02:46 AM
OrFordGuy's Avatar
OrFordGuy
OrFordGuy is offline
maybe some of you ford parts counter guys know the answer... can i replace a 78-79 dana 44 spindle with a dana 60 spindle for a strenght upgrade or are they the same and i'd accomplish nothing??????? if they will swap how many other parts do i need to swapap to complete the conversion...
Old 03-17-2011, 07:15 AM
79 shortbed lover's Avatar
79 shortbed lover
79 shortbed lover is offline
I dont think they will swap with each other
Old 03-17-2011, 07:21 AM
ford141's Avatar
ford141
ford141 is offline
No, the only shared parts between the D44HD and the D60 are the brake rotors and calipers.
Besides, I don't think the spindle/hub is the weakest part of the D44HD, the axleshafts are usually the first to go. I believe the weakest part of the D60 is the hubs and the outer stub shaft.
Old 03-17-2011, 01:28 PM
OrFordGuy's Avatar
OrFordGuy
thanks guys was actually looking to put dana 60 front drw hubs on my 44...aspart ofmy stuper dually project..
Old 03-17-2011, 02:10 PM
ford141's Avatar
ford141
ford141 is offline
Oh, just the dually adapters? Just unbolt the adapters from the D60 hubs and bolt them on to the D44 hubs. You are just doing this to run dually wheels on the front? Just for the looks to match the rear? I don't see any reason why they wouldn't fit.
Old 03-17-2011, 05:50 PM
OrFordGuy's Avatar
OrFordGuy
the 60 dually fronts actually mount the selector hub and i think the outer bearing and locknut asembly.. and yes i'm buiding a dually and dont want that sill 3/4 ton front dually rear look....as for adapters i've only found one of the right size....95-99 dodge 4X4 fronts...the chevy and gm are too short and the new fords are metric...p.s. my truck is a 4X4..
Old 03-18-2011, 06:43 AM
ford141's Avatar
ford141
ford141 is offline
Ya, the only duallies I've messed with are 2wds and the mid-90s 4x4 dodges and I know you can swap the adapters back and forth with no issues. Never messed with the 4x4 Ford dually stuff. Good to hear you found a solution.
Old 03-18-2011, 10:00 PM
OrFordGuy's Avatar
OrFordGuy
thanks guys.... if anyone comes accross those dodge hub apaters i'll buy them, pay shipping and toss in a finders fee...so long as its not stupid expensive..
Old 03-19-2011, 09:48 AM
akforceten's Avatar
akforceten
akforceten is offline
I used dually wheel adapters from a 95 3500 4x4 chevy the only thing is I had to use the chevy dually wheel cause the center is smaller than a ford wheel . The chevy adapter bolted nicely to 78-79 d44 hubs that I used .
Old 03-19-2011, 10:23 AM
91Bronc300's Avatar
91Bronc300
91Bronc300 is offline
You don't really HAVE to use the chevy wheels do you? It's the lugs that locate the wheel anyway. Or am I wrong?
Old 03-19-2011, 10:27 AM
akforceten's Avatar
akforceten
I put the ford rims on first and had a huge vibration an discovered that the ford wheel was not centering on the chevy adapter ! The chevy adapter has a lip on the center of the adapter for centering the wheel . When i put the chevy wheels on no more vibration !
Old 03-19-2011, 01:21 PM
tabascom16's Avatar
tabascom16
tabascom16 is offline
I dont see why you couldn't bolt on D60 spindles. All the brake parts including the dust shields and support bracket for the calipers are interchangeable so you would be able to bolts a spindle on. Only issue I see is that the outer axle shaft may not be long enough in your 44 to fit the whole way to the end of the D60 hub which may be a little longer and I know as a fact that even though they are the same diameter the D60 outer shafts have a larger spline count.
So as a whole it is not going to work.
Old 03-19-2011, 02:54 PM
OrFordGuy's Avatar
OrFordGuy
okay same deal on the chevy adapters, u find um i buy um and kick to you...so if the dana 60 spindle fits couldn't i use dana 55 ttb parts and the longer stubshaft with maybe some bast*** joints to fit the shaft along with the dana 55 hubs..then add the danas 60 dually hubs and call it good...
Old 04-03-2013, 08:04 PM
73f250highboy's Avatar
73f250highboy
73f250highboy is offline
I know this is old but I'm researching this myself and wanted to say that Dana 50 or 60 stub shafts won't fit in the 44 cause of u joint size.
On a side note how much would those Chevy adapters be worth?
BLDTruth
07-16-2017 03:50 PM
DirtWorx
19
11-28-2016 08:05 AM
78fordfan
08-21-2016 01:29 PM
650
04-05-2016 03:08 PM
Built_Ford_Tough_757
02-02-2012 05:00 AM
Quick Reply: dana 44 vs dana 60 spindle
