2000 7.3 WON'T START COLD - Ford Truck Enthusiasts Forums
Old 03-16-2011, 11:42 PM
SILVER STROKE SILVER STROKE is offline
SILVER STROKE is starting off with a positive reputation.
Relatives truck will not start he can pull it and it starts but that's the only way. Manual tranny of course.
Old 03-16-2011, 11:49 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
more info bud. What have you inspected, tried...etc.
Old 03-16-2011, 11:50 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
Has he tried plugging in the engine heater ?? If that helps, the glow plug system is not working..
Old 03-17-2011, 02:00 AM
Also you should check the glow plug relay's large terminal (left side) just after turning the key on (don't start engine) during a cold start up for 11 volts.. (will stay at about 11 volts for about 2 minutes).. No voltage here is a bad relay.. see my picture gallery of a glow plug relay..(large terminal on the right in the picture)
Old 03-17-2011, 02:55 AM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
I might be wrong but it reads to me as if its not even turning over......
U can try to jump large terminals on starter solenoid relay on passenger fender. If it starts then, check to see if small wire on that relay is getting power when key is turned. If it does, and both large terminals have power, then more than likely starter is bad.
Also, check both battery connections and voltages.
Old 03-17-2011, 11:40 AM
Brother Les's Avatar
Brother Les Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
Quote:
This is the 'cold start' threads that should help.
http://www.ford-trucks.com/forums/10...ky-thread.html
Old 03-17-2011, 09:26 PM
Its trying to turn over but not firing. Today it was 75 and it started fine.
Old 03-17-2011, 09:57 PM
Let us know when you have checked the possibilities listed in prior posts and report back, especially the cold start link in post #6...
KR and Platinum's starting to show up at dealerships? Skidooer16 2017 Super Duty 60 09-09-2016 02:29 PM
driving died, no start, started then died, started got home, now no start? B1GKAHUNA 6.0L Power Stroke Diesel 34 06-15-2014 03:05 PM
Remote start Jay 2007 - 2014 Expedition & Navigator 5 03-12-2014 12:06 AM
Remote Start abah 2004 - 2008 F150 4 10-13-2007 09:41 PM
351w no start Redneckerson 1987 - 1996 F150 & Larger F-Series Trucks 4 03-15-2002 08:49 PM
Tags
1999, 2000, 2003, 450, 73, 99, cold, diesel, f250, f350, ford, morning, start, starts, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
