7.3 Leaking at Fuel Filter - Ford Truck Enthusiasts Forums
Old 03-16-2011, 06:37 PM
dad2nick dad2nick is offline
dad2nick is starting off with a positive reputation.
Replaced filter and gaskets. Beveled side up. Still weeps. Hard to tell if it is leaking through the water drain pipe or around the pipe. Any thoughts?
Old 03-16-2011, 06:53 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
It's pretty common for the drain to leak... Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
Old 03-16-2011, 07:44 PM
Excellent, Thanks!
This is a great resource. Seems like a simple fix. I blew out the teflon O-ring on the back of the HPFP while towing my1954 Dodge Power Wagon in 90 degree Illinois heat of summer. Took four gallons of oil (including the engine oil and gear oil drained out of my Power Wagon), two rubber O-rings and some Form-A-Gasket to get me to Iowa where I got the last teflon O-ring the Ford dealer had in stock.
Old 03-16-2011, 08:05 PM
BigAlsPSD's Avatar
Ford probably would have them instock but usually if you can wait a few days its cheaper to order from Bob(Diesel orings) or Clay(Riffraff Diesel)
Can a dirty air filter cause a P132b code? Restlesswildman 6.0L Power Stroke Diesel 9 06-26-2016 10:17 PM
Fuel filter seperater Matseffie Australia Chapter 3 07-20-2014 04:25 AM
Quick question - fuel leak cowmilker08 1994.5 - 1997 7.3L Power Stroke Diesel 5 02-13-2014 08:52 AM
Up pipes on a early 99 ltl_jrw 1999 - 2003 7.3L Power Stroke Diesel 3 05-24-2011 05:38 AM
Exhaust leak is driving me crazy....... John7894 1999 - 2003 7.3L Power Stroke Diesel 10 02-22-2006 02:25 PM
Tags
73, diesel, f350, filter, ford, fuel, fule, leak, leaking, leaks, location, power, powerstroke, pump, strock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
