Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 03-16-2011, 07:05 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to all
Cardon Joint Bearing
Anyone ever replace the Centering Yoke bearing on the double cardon joint? I am replacing my u-joints tonight and the little bearing and spring assembly that keeps the tension on the double cardon joint is in serious need of replacement. Has anyone ever seen a place where you can buy the bearing all by itself? I can get the whole centering yoke for $45 from Rock Auto, but I don't need the whole yoke, just the bearing.
I don't suppose it would be advisable to reassemble this thing without that spring and bearing either.
Any input is helpful.
Thanks.
__________________
--Nate "Just a redneck geek"
1997 F-350 7.3 PSD, 4x4, CCLB SRW, 3.55's, ZF5
If it isn't under warranty, I'll fix it myself.
Old 03-16-2011, 07:12 PM
84-250 84-250 is offline
84-250 is gaining momentum as a positive member of FTE.
dont know where in NE ohio you are but in cleveland I had custom clutch rebuild a double carden front shaft with 3 new spicer joints and balanced for about $200
You could see if they have your part
__________________
1994.5 F350 CC PSD 5sp 4x4
T409 Downpipe & Cat Delete, 6637, Valair 01HD Clutch,
140V IDM, Pyro, Terminator Scangauge, Beans Tunes, Full Force Stage 1s, Traction Bars, E-fuel
1984 F250 (RIP) PM me for parts
Old 03-16-2011, 08:13 PM
Thanks for the info. I don't really need the shaft rebuilt since I have three new u-joints already here, but worse come to worse I might give them a call and see whether they can get just the bearing.
__________________
Old 03-16-2011, 10:29 PM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
I would love to know how to do this. I hear it is a total BIOTCH!!!.
Would you care to take pics and/or tell me what you had to do? I have one that I would like to rebuild myself.
Thanks
__________________
97 F250 Full Force 275/200's, DP Tuner Live Tuned, Modded H2E, Terminated HPOS, Comp 910's, ARP studs, Swamps Pushrods, 6.oh Cooler, BDP elec. reg. return fuel, Valair dual disc clutch, RSK, D60, SD 1 ton springs DRD INMATE # 40
Neal's Pics and H2E install
Tennessee Chapter Member Join Chapter here
Old 03-17-2011, 06:29 AM
I will try to remember to take some pics as I am putting things back together. One thing I will say is that I don't think I would have been able to do it if I didn't have a cutting torch. The front U-Joint in the double cardon joint was basically too big to be removed by pressing (driving) out the caps. I just cut it out with a torch and then drove the caps into the center of the joint. The cross of the u-joint actually hits the inside of the yoke before the caps come loose.
I will snap some pictures as I finish things up and this description will make a lot more sense.
Anybody else know where to get the bearing for this thing? Otherwise I guess I will be ordering the whole yoke for $45.
Bueller......
Bueller..........
__________________
Old 03-17-2011, 08:39 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
I rebuilt my own double cardan about 6 years ago but I can't picture what centering bearing you're talking about.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
Old 03-17-2011, 11:44 AM
The bearing I need is part of this assembly.
Click the image to open in full size.
I thought from the look of it that the bearing may be replaceable by itself, but I am not finding anything. Ordered it from Rock Auto. Should be here in a day or two.
This is actually the front half of the yoke that comes out of the transfer case. the bearing and spring keep everything centered as much as possible, I assume to minimize vibration coming from the double Cardon Joint.
__________________
Old 03-17-2011, 01:31 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I think you had to get the whole piece. I replaced the one on my 76 last fall and had to get that part just like that one.
__________________
Darin 99 ranger 76F250 66 fairlane
"TheBeast"1997F2504x4dually4.10's,160k,140VIDM,HPX ,4-5"dp, S366 turbo w/wicked wheel, 6637, elec. fuel,rosewood stage ones,php hydra,arp studs, comp springs, smith brothers push rods, honeybadgerjr hpop,riffraff res,melling lpop,180 tstat,6.0 fan and IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and billet converter, upgraded trans, F550 leaf springs,SD dual tensioner upgrade, cold ac mod
Old 03-17-2011, 11:10 PM
Mars57 Mars57 is offline
Mars57 is starting off with a positive reputation.
There is a web site for Ford Explorers where a guy explains how to replace the bearing you are referring to. If you can get the assembly for 45 bones I would just go that route, way easier, the bearing is pressed in and you have to cut ,grind and chisel the old one out. I paid 120 bucks for that same assembly. Spend the 45.
Al
Old 03-26-2011, 04:27 PM
Update
Just a quick update. I got my parts from Rock Auto on Thursday and re-assembled everything in about 30 minutes time. About 15 to put the joint back together and another 15 to put the drive shaft and skid plates back on the truck. Not a bad job at all. Here are some pics.
Self Centering Yoke with bearing.
Bearing pin on the front U-joint Carrier
Assembled Self Centering Joint
Assembled Joint
Not a bad job all in all. I'm not sure how I would have gotten the front u-joint out of the carrier without a cutting torch though. The carrier is not wide enough to allow the u-joint to move far enough to drive the caps out one at a time.
At any rate, there's the update and this did, indeed, solve the issue I was having with my "chirping" 4 wheel drive.
__________________
Old 03-26-2011, 04:44 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw has a great reputation on FTE.pjwoolw has a great reputation on FTE.pjwoolw has a great reputation on FTE.pjwoolw has a great reputation on FTE.pjwoolw has a great reputation on FTE.
Nice work Nate. I've never had to go through one of those.
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab 1.0 housing Banks wheel AC injectors T500 Farmers Diesel pushrods Diamond Eye 4" exhaust DP F6 chip Electric fuel S@B intake
Old 03-26-2011, 05:23 PM
Looks good Nate. That's the same thing I had to do to my 76 highboy. Same parts replaced and all. I used a portable band saw to cut my joint out, I know what you mean there.
__________________
Old 03-26-2011, 06:45 PM
Quote:
Yeah, A porta-band would work pretty good too I guess, or even a sawzall with a metal blade. For that matter, I guess you could get the job done with a sharp hacksaw and a generous application o f elbow grease. The good 'ol red wrench just makes short work of jobs like this.
__________________
Old 03-26-2011, 11:27 PM
Thanks a ton forthe update and pics.
Now I believe I could do thi s, now having seen one taken apart.
Reps sent.
__________________
Old 11-15-2014, 11:05 AM
LeoJr LeoJr is offline
LeoJr is starting off with a positive reputation.
Quote:
Though this pic is of the finished process, it also represents the old unit and the problem with the disassembly?
I may try this on my donor front shaft. Thanks, the pics really help!
Referencing this picture… Could both U joints that have their caps at the top 12 o'clock position be pushed the same direction at the same time allowing disassembly without a band saw or torch?
Not literally at the same time. I mean push one a little, then the other, and so on.
Thanks!
__________________
*1996 F250 crew cab/short bed, 4x4, auto PSD*Looking for gray 40/20/40 seats, I have a dirty set of blue I'd trade *stainless window vents *remote door locks work with engine running mod.
Link to my D60 refurb and OBS swap thread Link to my OBS air vent R&R thread Link to my grab handle install
Link to my tire size comparison pics
Similar Threads
2008 F250 Std. Cab RWD U-Joint swap. TexasRebel Super Duty & Heavy Duty 0 06-22-2014 11:24 PM
Rear U-joint disintegrated Encho 1987 - 1996 F150 & Larger F-Series Trucks 43 06-20-2014 02:18 PM
longer driveshaft, more angle? where to buy? ErrorS 1978 - 1996 Big Bronco 9 12-01-2012 04:43 PM
97F350 w/4407tc broke front yoke any replacements? banshford 1994.5 - 1997 7.3L Power Stroke Diesel 7 12-22-2009 08:53 AM
help!! need to find f-350 front t-case output yoke c00nhunterjoe 1994.5 - 1997 7.3L Power Stroke Diesel 15 10-30-2009 09:02 PM
Tags
1996, 73, cadon, cardon, centering, de, double, expedition, ford, joint, pic, repair, transit, turbo, ujoint, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
