Ball Joint issue
Old 03-16-2011, 12:05 AM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Ball Joint issue
Hey guys. I feel pretty dumb right now. I've never had this problem doing ball joints. I was putting the knuckles back on the truck tonight with new MOOG ball joints. Got one side done, no problem. Now onto the passenger side. Get the upper ball joint tightened up. Move to the lower. The lower ball joint uses a staked nut. When the staked part of the nut got to the stud, it just spun the stud rather than tightening down. I cannot for the life of me get this thing to tighten down. I've tried sticking a screwdriver in the slot on top of the stud and using a wrench, nothing... It just spins the stud no matter what I do. Anyone else had this problem with your ball joints? How did you solve it? Now I'm having trouble even getting the nut back off since the stud is spinning like that. Oh and the nut is not cross threaded or anything. Maybe there is something I'm not thinking about for some reason. Thanks fellas.
Old 03-16-2011, 12:28 AM
Elderstarr's Avatar
Elderstarr
Elderstarr is offline
Try setting a jack under the knuckle to press it upward, locking the tapered stud into the body of the knuckle, then turning the nut.
Old 03-16-2011, 12:51 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Or use a socket wrench (the bigger the better) with the 1/4 socket and a size 10 slot screwdriver bit, with the added leverage you will be able to prevent the stud from turning while you tighten the nut. Weird enough, i once used a camping axe's edge on the slot (it worked quite well actually).
Old 03-16-2011, 01:39 AM
strokin'_tatsch
Hmm.. I will throw a jack under it tomorrow night and see what happens. I guess this is kinda common, just never has happened to me. LOL. If that doesn't work I will try again with a socket and screwdriver bit. Thanks guys. reps to both of ya
66ca
05-08-2023 02:29 PM
waylen89
16
08-31-2015 08:55 PM
johntpr
05-28-2013 10:57 AM
boosteddsm
06-26-2011 04:45 PM
gibsonj
07-05-2005 10:29 PM
Quick Reply: Ball Joint issue
