58 steering box trouble shooting
Dustin,there have been some recent discussions,both here and on other sites,regarding the less-than-stellar quality of Coker Tires.True,our trucks were designed for bias plys' ,but using as narrow a radial as you can find,and avoiding big "meats" has worked for me for years on a daily driver. I won't pay premium prices for average or below average tires.I also use an illegal suicide ****(we referred to those in an un-politically correct manner "back in the day") that helps my un-Popeye like 51 year-old arms avoid fatigue on our mountain roads.I won't argue about the stresses placed on stock rims designed for Bias ply tires,that's been argued to death,though not on a par with Widowmakers.I use stock wheels...........
That's why I'm looking for a nice white steering wheel,but I can't bear to look at my current one when that **** is removed - it is chewed-up after 52 years.We in Ohio called those ***** by a term that referred to those Cadillac-owners who most favored their use.I'm more enlightened now.They were illegal in Ohio,but so was driving barefoot,and we always drove barefoot.Since I've only lived here 30 years,I can't keep my state driving laws clear in my mind!
not
This is a very common mistake.
Gear lube (oil) is not used in manual steering gearboxes. These gearboxes use steering gear grease. Available at autoparts stores and from Ford.
The gearbox (sector shaft) seal is not designed for oil, so when oil is present, the gearbox begins leaking within a short time. Using oil causes the steering to become loosy-goosy.
FTE member ibuzzard used steering gear grease in his truck. Said it made all the difference in the world how it steers.
These gearboxes have an adjustment nut used to set the sector shaft's preload. People make the mistake of over tightning it...the result is: super stiff steering.
Here's a comparison between the two:
Michelin AG - Advantages - Bias vs Radial
You can run radial tires, however they should be the same section width as the originals in order to reduce steering component wear and rubbing on the frame at the steering stops. If you wish to use wider tires, steering effort will be increased and wear on the steering components accelerated. If the wider tires contact the frame at the steering stops, the steering stop adjusters can be adjusted to set the new maximum steering deflection. The stops are horizontal screws located on the spindle arms. Regardless of which tire you chose, keep in mind the suspension was designed for bias-ply tires. Running radial tires will alter the handling and ride of the vehicle.
Caveman2851
08-14-2015 08:38 AM
