Fixing a floor jack that won't stay up - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 03-15-2011, 05:48 PM
dethomson dethomson is offline
dethomson is starting off with a positive reputation.
I have a 3T floor jack that pumps up, but won't hold. It starts to settle back down as soon as I stop the pump stroke. No, I'm not overloading the jack.
What's wrong? Does it just need to be bled or what?
It did this a bunch of years ago but seemed to self correct after leaving it alone for a real long time. It was working great, but got left outside back in the fall and got wet. I pulled it into the garage when I realized it was outside, but didn't try to use it until recently. I had to break out a bottle jack.
Old 03-15-2011, 07:37 PM
planehunter's Avatar
planehunter planehunter is offline
planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.
If your fluid level is good, then the seals are shot. If you know the brand, you can usually find a rebuild kit. If you don't know the brand you will have to take it apart and take all the seals and gaskets to a bearing house to have them matched up. If the main piston is scored from rust (left outside) it sould probably be cheaper and easier to replace it with a new unit.
Old 03-15-2011, 07:41 PM
It's a Sears and is a really good jack except this that's happened twice now. I'll check the fluid level. I never leave the jack up or use it harshly, so the piston should look pretty good. I'll check that too though.
Old 03-16-2011, 01:05 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
A piece of dirt or debris can become lodged under a check ball and cause the same thing. Change oil and flush it out with some hydraulic oil, NOT BRAKE FLUID! ATF would work OK.
Old 03-16-2011, 05:59 PM
Sears should have rebuild kits for it, they will need serial number to locate the kit. You could try changing the oil, couldn't hurt.
Old 03-23-2011, 05:25 PM
brownfoot brownfoot is offline
brownfoot is starting off with a positive reputation.
don't count on Sears having the rebuild kit, they didn't for mine.........about a '79 model
was able to clean, replace o-rings by matching, replace oil (used hydralic jack oil from Tractor Supply)
works fine now
Old 03-23-2011, 08:47 PM
Outstanding job, and be careful when jacking......lol.
Old 05-02-2011, 05:10 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
A little viagra will help the seals swell back up
Jacking up the truck BlackNM6.0 6.7L Power Stroke Diesel 13 04-18-2015 11:39 PM
How to jack up my truck to bleed power steering 44nneedit 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 06-05-2013 09:41 PM
Jack questions... mark996 Excursion - King of SUVs 7 06-02-2011 08:07 AM
Floor Jack not working anymore 78ford351m 1973 - 1979 F-100 & Larger F-Series Trucks 12 10-10-2010 11:35 PM
How do you Jack up a truck? Hawke 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 05-02-2009 04:56 AM
Tags
1983, anymore, bottle, car, floor, floorjack, ford, hydraulic, jack, repair, sears, stay, staying, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
