How to change your V-10 spark plugs.
on
Start with the left front hole after all your plugs are gapped, take your 7mm socket and remove the cop hold down screw but grab it carefully and place it above the radiator so you don't drop it, pull the cop wire (easy) if you plan to replace the boot, pull out the cop and boot, use a plug socket with the rubber insert so your plug will come out of the hole and if that doesn't work you can spray the inside of the socket with adhesive (this is what I do because the insert is gone), pull the plug and replace with your new gapped Autolite 103, check your cop boot for cracks and dirt etc, if they are cracked they are worthless but otherwise you can clean them up, put a tiny bit of grease on the spring tip, put dialectric all around the top 1/2" of the boot (I use axle grease because i'm cheap and couldn't find any other than little packets), this will seal out the water and dirt, torque plug at 14 pounds if you like (I don't torque mine and they are always snug when I replace them every 2 years)....... no need to get on my case here, button that first one back up (do 1 at a time so you make sure they are tight, actually in there, and to minimize dropping anything in the hole), do the rest but when you get to the right rear 2 remove the throttle bracket and the bracket across from it (easy), twist off the hose going to the throttle body and any other hoses you can easily remove back there, remove the last 2 cop wires back there and any other wires that will come off (easy), tuck the wires away and tie all the loose hoses back with duct tape, get the proper extension with a socket taped to it with a little electricians tape, (so you don't drop the socket in the hole). Don't use a bunch of duct tape on the socket because if it comes apart you might not get the socket out.......just a little black tape. It takes me about an hour to change them after I am all set up and I use a short ladder to get up in there.
on
Technically everything is from the drivers view so the left side is also the drivers side (or the right side looking from the front of the hood). It's kind of like your left hand is on THE right looking FROM the front. The tough plugs to get to are on the left side looking FROM the front. (passenger side).
on
The gap is .052 to .056 and the same for the v-8. The boots are in ebay with what they fit and those boots will fit the 5.4 v-8 also. I just got 8 aftermarket ones and kept my best 2 after cleaning them up. They are dead ringers for the oem ones.
on
If you do like I said as the OP, a regular ratchet works fine and keeps the set-up nicely lined up.......just my opinion. Even the tranny stick comes out and then there is a straight shot at it (well worth it on # 5 hole) also, Wp has too much grease on one end and not enough on the other. You need to just keep the end of the spring form corroding and the water out.
Here's a whole set of 10 boots on ebay for $20.00. They say they are Carquest brand.
SPARK PLUG BOOT SET FORD F250 350 450 550 EXCURSION V10 - eBay (item 170613425207 end time Apr-07-11 20:12:17 PDT)
on
