Auto Transmission Shifting Issues
#197
Boys...if you're having an issue, call the dealer, ask them to document it in your file, send a registered letter to Ford and the dealer and keep detailed records (video if you can do that) for your own protection. While I'm sure Ford will resolve this, better to err on the side of caution and protect yourselves.
#198
Joe
#199
Same here
I've noticed this transmission issue almost from the week I purchased by 350 last July. I've been on extended business travel lately but noticed it again when I returned.
I called two dealerships and they both very easily played dumb.
A couple of questions:
1. Is there a later flash after the 400/800 flash? If so, does it address this issue?
2. (While I detest having to compensate for faulty technology) Is there a way of driving that would minimize the obvious slam on the transmission when this occurs?
Thanks, It's good to be back on the forum
#200
#202
#203
I can't exactly remember the TSB for it right now but it may have been the 10-23-9 release.
It does address this issue but did not resolve it.
2.) I have had this happen with different styles of driving so it's hard to prevent it.
What I consider normal is keeping it under 2,000 RPM with steady acceleration (not putt-putting or hard acceleration).
The truck seems to prefer the 1,800 to 1,900 RPM shifts for the first 3-4 gears.
5th and 6th are never an issue and if I remember correctly and haven't been with my truck.
Too low of RPM during a shift causes the shift and lurch.
Since most of the time this happens when the transmission has cooled off, you want to take it easy accelerating anyways.
But I've had the issue with the entire truck at OT, too.
Lots of words, hard to explain.
I've tried to learn when the truck will normally shift based on RPM's and my right foot.
Everyone drives differently so you might be able to figure out, depending on the conditions and your right foot, how your truck behaves with different levels of accleration.
I've been using manual mode more often, too.
This is where I discovered the issue exists when in manual mode the other day (only worse) when I forced a shift command to the TCM.
#204
While I have been following this thread closely since the beginning ,I have been waiting for my transmission to do something funny and it hasn't.....up until now. 1000 mi on the truck, built in Jan, not a single issue on anything. However, last evening it happened.
While pulling away from a light, up a mild grade, the "Exhaust Cleaning" message flashed, just as I lifted my foot from the brake to the gas pedal, and the transmission went bonkers. While accelerating up the slight hill it purely acted as if it didn't know what gear it wanted to find. It continued as if it was confused, until I finally let off the gas and everything was fine.
It instantly occured to me there were two tasks on the network at exactly the same time and there was a collision of network traffic resulting in what I refer to as "Bits Falling Out Of The Bit Bucket". I really wonder if this was just pure coincidence.
Now add my name to the list of the legions awaiting the FOMC response.
#205
there shouldn't have been any collisions since it's a bus, not a full-on network. Things get dropped into a queue to be processed by the appropriate handlers. I am not saying it was coincidence, just perhaps better explained in another way. For instance, it may be that the active regen cycle exacerbated the conditions which were already leaning towards causing the issue.
#206
#207
Ironically I had my first tranmission shifting issue on my way to the dealer yesterday for round #2 on recall 10S14. When shifting from 2nd to 3rd it missed the shift and the engine reved up until I let of the pedal. I also continue to experience harsh shifts from 2nd to 3rd and 4th to 5th. I let the tech know and he was aware of the problem and told me to check back in a couple of weeks. I hope there is a fix soon.
#208
Well, gents checked my fluid this morning and all seems ok for now. Called dealership to get an appointment to have them look at the truck and the Service representative told me Ford was aware of the problem and I asked him if I should keep driving the truck since I'm concerned about possible transmission damage, to which he replied "I would try not drive it as much as possible if I were you but if you do your truck is still under warranty"
#209
I am fairly confident I do not understand the truck brain architecture and I am sure I wont solve the issue I had, I am confident FORD can and will.
Just wondering.
#210
