Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-15-2011, 12:57 PM
Vaccuum Vaccuum is offline
Garage is empty, add now
Vaccuum is starting off with a positive reputation.
Headlight adjustment on F-150
I replaced the lamps and now I am remounting them.
What is the procedure for adjusting the headlight on a 2002 F-150, V8, 5.4, 2WD?
I need to align the light beams.
Thanks,
Mike
  #2 (permalink)
Old 03-23-2011, 12:40 PM
Nobody? Nobody knows how high they should when facing a wall? Before I put the grill back on, I want to know the set up.
Somebody, somewhere must know, they just aren't telling me.
Hmm.
Thanks,
  #3 (permalink)
Hmm.
Thanks,
  #4 (permalink)
Old 03-23-2011, 09:43 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a good reputation on FTE.steve(ill) has a good reputation on FTE.
i park on the flat facing the garage door. adjust then so they are basically horizontal meaning if the llights are 32 inches off the ground, get the light pattern on the door 32 inches up from the ground. On the width, the main light beam should for left and right will be about 5 ft apart on the door in front of you. Of course the beam spreads out and will shine into the left lane and off the side of the road, but that looksmore like a reflection on the door.. The real conclusion is to drive it down the road at night and see what i think. I normally do this and see register in my own mind that the drivers side needs to move (up- dowon- left-right) , etc, then the passenger side needs ???. Go back to the driveway, make minor adjustments and do it again on the road. I have never got it right the first time without a road test and movement.
__________________
2002 SuperCrew 4 x 4 5.4 XLT -100K miles -NEW
2010 EDGE FWD - V6 ----------30,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 162,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
Tags
01, 150, 1997, 2002, 2004, 2005, adjusting, adjustment, ajustment, f150, ford, headlight, headlights, tool, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
