Some Sc II codes for "Xgauge" (Now injectors)
  #166
Old 06-30-2011, 02:25 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Originally Posted by BLADE35
yesterday I tried the manafold air temp or MAT
I put the code in and it came back -40 so WTF did I use the wrong code again
I didnt even watch it after I saw that it said -40
heres the code I used
TXD= 07E02216A8
RXF= 0462051606E0
RXD= 3008
MTH= 00010001
NAM= MAT
MTH= 00090005FFD8
thanks for checking my code out
That's what it reads for me too, Benny. I think there is a code for IAT2. IAT1 is read at the MAF as fIA on SG2.
  #167
Old 06-30-2011, 02:26 PM
npccpartsman
Originally Posted by Rusty Axlerod
Mebbe flash version?
I'm sure it is because we run different tunes in our trucks. My main objective was to verify that the SG2 Xgauge code for fan speed was accurate and it is.
  #168
Old 06-30-2011, 04:40 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Ok thanks Tim I thought I was going code crazy
yes I watched the preprogrammed fIA and Figured it was the one at the MAF too by the way it would get hot if it sat and would cool alittle when it got air flow to about ambeint temp on the over head lieometer
I will try IA2
have you found anything for MAF sensor the air flow half of the sensor on SGII
  #169
Old 07-05-2011, 06:58 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Has anyone entered the ICP volts gauge?
Has it worked in an 03-04?
Has it worked in an 05-07?
It hasn't worked in my 04, and it would good to hear if it is working on any of the model years.
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
  #170
Old 07-07-2011, 08:40 PM
Lumberg's Avatar
Lumberg
Lumberg is offline
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
Your listed code is valid for my '05 Xcar.
Regards.
  #171
Old 07-07-2011, 11:31 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
hey Sean Im pretty shure Im getting ICP volts to I will double check the codes tommorrow and post back
havent watched that one much mostley just the regular ICP pressure one
  #172
Old 07-08-2011, 06:53 PM
amdriven2liv
I figured out my issue with that gauge! It works, I hope it's accurate. See my new thread on ICP Readings.
  #173
Old 07-11-2011, 04:31 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
...Bump...
  #174
Old 07-21-2011, 10:02 PM
autonoz's Avatar
autonoz
autonoz is offline
Anyone having trouble with the fuel level get theirs to work?
  #175
Old 07-21-2011, 10:24 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Im pretty shure you can program a fuel reading for an X-gauge
havent tried that one
what code did you use
FL Fuel Level TXD: 007E02216C1 RXF: 0462451606C1 RXD: 3010 MTH: 000101480000 NAM: FL
thats a quick one
  #176
Old 07-22-2011, 06:30 AM
npccpartsman
FL Fuel Level TXD: 07E02216C1 RXF: 0462451606C1 RXD: 3010 MTH: 000101480000 NAM: FL
thats a quick one
Too many zeros in the TXD. I fixed it.
  #177
Old 07-22-2011, 02:31 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Thanks Tim I didnt know
I just got it from one of the pdf files that I saved looks like they need to be gone thru and updated with the proper operating values with it and the updated codes
  #178
Old 07-22-2011, 07:27 PM
winged1dur's Avatar
winged1dur
winged1dur is offline
I'm trying to track my my EOT and used the two different codes that I found in this thread but I can't get any readouts. What am I doing wrong?
  #179
Old 07-22-2011, 07:34 PM
amdriven2liv
I have used each code and both have worked. I am sure you have done this, but make sure you have entered everything right. I was sure I had on many of these codes, only to sleep on it then gone and seen I hadn't. (see a few posts up, perfect example!)
Make sure you hit save.
  #180
Old 07-22-2011, 09:18 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
no kidding go to double check those codes I entered one for the fan and it actully read something I was surprised it even read after I found I blew the code on 2 of the entries
Quick Reply: Some Sc II codes for "Xgauge" (Now injectors)
