AEM cold air intake
AEM cold air intake
Looking at the ridiculous amount of baffling on my 08 expy today...I really want the aem intake but they only fit the f150 (it says). Is there really much of a difference? I prefer the aem to the k&n so I may have to check out my stepfathers 09 f150 to see if its a similar layout.
Is the intake the only modification you're going to make?
Reason I ask is that the baffling on the stock intake is actually not restrictive, it's just a noise cancelling agent. The flow of the stock intake is actually very well matched to the 5.4L's performance, and the aftermarket intake will likely only give you gains, if any at all, above 5k RPM.
The aftermarket offerings are commonly referred to as "engine bling" for a reason...they provide little to no performance improvement over stock, but they might look better. Secondly the aftermarket intakes usually pull air from the engine bay, whereas the stock intake pulls from the fender well, which should be cooler air.
Honestly, you'd be better off going with a hand held tuner/programmer with custom tunes, as you're likely to see both performance gains and possibly economy gains depending on your driving style.
EDIT:
Here's a similar thread from just a few days ago...was right on the first page of the forum:
https://www.ford-trucks.com/forums/1...-worth-it.html
EDIT:
Thanks, I read that already. Ill put one on anyways seeing that my other 5.4 got a bout 1.5 mpg increase from an intake.
P.s. it sure seems like with all the baffles and ports would cause unnecessary air turbulence...thus slowingg flow down?
P.p.s. I still need to know if the engine bay between a 2009 f150 and 2008 expedition are similar enough to accommodate the same intake...I read the installation instructions and it sure looks the same. Would love to hear from anyone who tried it though!
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
07-11-2017 08:06 AM
SWAT KHAN
1997 - 2003 F150
05-13-2012 09:52 PM
Dalamatition
01-04-2005 10:55 AM
