High Idle mod question
In park I noticed that when HIM is on I have more boost pressure than when I (HIM off) put the throttle at 1,200 rpm... And when I have my foot at 1,200 rpm and then put HIM on, the rpms drop. Another situation I had HIM on with my foot holding the eng at 1,400 rpm and then turned HIM off and the rpms when up.
Is this because of the turbo boosting? and/or is there more going on?
Thanks
Thanks
I wonder if you did the SEIC or the BCP? Just guessing here, but with SEIC it locks the torque converter and is designed to provide power to a take-off device. That would require some boost. With BCP it is just idle to drive the alternator. No boost needed. Other than that, I cannot explain the behavior you are seeing.
What are the wire colors? pics?
BCP = Purple/Green Stripe
SEIC = Solid Orange
from here:
http://www.thedieselstop.com/content...%20High%20Idle
SEIC = Solid Orange
from here:
