66 Short Styleside - Page 7 - Ford Truck Enthusiasts Forums
66 Short Styleside
  #91
Old 06-24-2014, 11:29 PM
shortwide's Avatar
shortwide shortwide is offline
shortwide is starting off with a positive reputation.
I switched out the rectangle mirrors on the 66 for the proper little round mirrors.
And I also pulled the front bumper and painted it Wimbledon White instead of the brighter white that it was.
Two simple but effective improvements.
Here's a before and after.
  #92
Old 06-24-2014, 11:30 PM
shortwide's Avatar
Next task is to pull of the rear bumper and install the pretty contour bumper that I have for this truck.
I tried removing the hardware holding on the the current bumper but it wasn't budging.
I'll attack it again soon with a cheater bar.
  #93
Old 08-02-2014, 10:19 PM
shortwide's Avatar
Bumper Update:
I got all situated with my cheater bar and bottle of penetrating oil, and was ready for the task of removing the nasty old rear bumper on my 66 when I discovered, much to my chagrin, that it was welded onto the bottom of the frame rails.
No worries, I dusted off my oxyacetylene torch and cut the sucker off.
Then I mounted up the contour bumper.
I think it's a noticeable improvement. Next is to repaint the FORD letters on the tailgate and then try to rub some life back in the old Sahara Beige paint.
Here's a before and after set of photos.
  #94
Old 08-03-2014, 10:26 AM
bertha66's Avatar
bertha66 bertha66 is offline
bertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud of
That does look a lot better!!!
  #95
Old 10-19-2014, 11:27 AM
Roger C's Avatar
Roger C Roger C is offline
Roger C is starting off with a positive reputation.
Safelite Sucks
Quote:
Originally Posted by Broomfieldbum View Post
I called my local Safelite Auto Glass and they told me it would be $250 to replace the seal, (using their seal) It would be $375 if they replaced the glass they would also not guarantee they would not break the glass getting it out and back in. I have decided to wait until I can replace the glass also. Mine is not broken, but it is pitted.
I install Glass for a living and safelite is a Ripoff. Their glass is poor quality as is their installers. The gaskets are not Safelite fortunately. My cost for the 66 gaskets are less than 50.00. My 66 CS was installed by safelite before I owned it and it leaks and the Glass is de-laminating. Just my 2 cents worth. If you are careful you can do it yourself and save a ton of money. If you have any rock chips in the windshield don't bother re using it as it will probably crack out.
WTB - -SWB Right floor section behind fenderwell for dent hooverdammatt WTB - Parts & other 0 08-02-2016 07:49 PM
(5) 1961 to 66 front fenders mrcman58 Ford Truck Parts for Sale 7 10-02-2015 03:14 PM
64-66 Styleside Taillight Lenses - Are all reproductions created equal? trossol 1961 - 1966 F-100 & Larger F-Series Trucks 3 10-01-2015 05:33 PM
1963 F100 292,T98A,4x2 57 short bed--what is it worth?? phoneman91 1961 - 1966 F-100 & Larger F-Series Trucks 12 11-28-2014 02:27 AM
Bedside tool box installation andgott 1961 - 1966 F-100 & Larger F-Series Trucks 19 09-10-2013 12:04 PM
Tags
1963, 1980, 5486, antique, bed, box, gmc, original, paint, panels, preserve, replacement, short, steps, stepside, styleside, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
