302 to 300 6 cyl swap questions
so i am in the army and got orders to korea and planning on taking my 92 f150 if allowed. it is burning oil and has blow by. my friend has a 300 inline 6 with about 40,000 miles on it that i am wanting to swap in.
questions:
will my ACC. bolt up from the 302?
are the motor mounts the same? if not what needs to be swapped?
it is a carburated motor so will i run into issues with the cluster or electronic trans?\
anything else i should know about the swap that has not been mentioned?
thanks other than an 86 bronco i had for a short time this is my first ford so they are a little foreign to me i am used to VW's
questions:
on
You're gonna have to remove the electric fuel pump in your gas tank and put in a regular pickup tube and screen.
This kind of swap goes a LOT smoother if you have a complete donor truck.
Beaner weiner
12-05-2013 07:35 PM
Orange84
10-16-2013 12:16 AM
